I'm a loser, baby.
oregonmon's Avatar
Backfiring on acceleration
I have had this symptom of stuttering on hard acceleration at rpms above 4000. Wasn't sure what to think but here is another symptom related I'm sure that might let you guys steer me towards the right remedy.
Since then I have put on a Fabspeed muffler bypass so the exhaust is much more aggressive. On this last drive home really hammering it on the back roads it was backfiring on hard acceleration. Never on deceleration.
Spark issue? Have ran two cans of Seafoam through the last two tanks too.
Thoughts?
Thanks.
P.S. The muffler bypass is sweet.
1979 911 SC
Old 05-07-2008, 07:57 PM
Air Medal or two
afterburn 549's Avatar
I wouid guess fouled plugs or a weak secondary unit. KISS. TRY new plugs and report
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 05-07-2008, 08:19 PM
Max Sluiter
Flieger's Avatar
Detonation?
If so, timing adjustments may help. Make sure you are running the best fuel you can find.
Give the engine a work out to get rid of any carbon deposits that cause heat retention and sharp spots in the combustion chamber.
Check spark plugs and maybe clean fuel injectors (remove and inspect the spray pattern in a glass jar)
Old 05-07-2008, 09:26 PM
I'm a loser, baby.
oregonmon's Avatar
Detonation?
THAT I've done.
1979 911 SC
Old 05-07-2008, 09:44 PM
Bye, Bye.
Scooter's Avatar
Check fuel pump/filter.
Elvis has left the building.
Old 05-07-2008, 09:46 PM
I'm a loser, baby.
oregonmon's Avatar
Fuel filter replaced a few months ago.
1979 911 SC
Old 05-07-2008, 09:58 PM
Bye, Bye.
Scooter's Avatar
Could still be the pump or a bad batch of gas could have clogged the filter. It might me worth a look.
Old 05-07-2008, 10:04 PM
I'm a loser, baby.
oregonmon's Avatar
Well the stuttering has been going on for over a couple months now and I think the backfiring and stuttering is hand in hand. I just never had the backfiring I guess the stock muffler, well muffled it. If I really get on it, above say 4000rpms it start to do it, then if I ease of the throttle just a bit it smoothes out. Once I ran to about 6 grand in 2nd gear and came to an abrupt stop and let it idle and is was like it was missing on a cylinder. Mechanic replaced plugs a few thousand miles ago but could it be wires or distributor? Still, relatively cheap to change plugs anyway.
1979 911 SC
Old 05-07-2008, 10:39 PM
I'm a loser, baby.
oregonmon's Avatar
Bringing it around again.
1979 911 SC
Old 05-08-2008, 10:17 AM
Air Medal or two
Did you check the secondary ?
Old 05-11-2008, 02:10 PM
Make Bruins Great Again
Por_sha911's Avatar
While idling, pull one plug wire at a time and see if the idle changes. That will tell you if its an isolated cylinder.
Old 05-11-2008, 02:15 PM
I'm a loser, baby.
oregonmon's Avatar
Come again?
1979 911 SC
Old 05-11-2008, 03:37 PM
I'm a loser, baby.
oregonmon's Avatar
Well it doesn't run rough at idle only at heavy load and high rpms.
1979 911 SC
Old 05-11-2008, 03:38 PM
pozee's Avatar
Does yours have the RPM/crank position sensors?
pozee
Old 05-11-2008, 05:51 PM
I'm a loser, baby.
oregonmon's Avatar
Huh? Are you guys pulling my chain? Seriously, are these real questions? If the next guy asks me to replace the muffler bearing I'm gonna be pissed?
1979 911 SC
Old 05-11-2008, 11:13 PM
Designer King
Paulporsche's Avatar
Sometimes going to more of a free flowing exhaust means you have to richen the mixture. If you try that, do a test drive and report back.
If that doesn't do it, then you have to start going through everything: timing, ignition, fuel delivery, dizzy advance, WUR, etc. I like to try the simple stuff first.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-12-2008, 05:06 AM
1979 911 SC
if it's ignition wild guess is failing Beru connectors
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-12-2008, 05:47 AM
Air Medal or two
Ok , Now I will tell. Please change out the pluds (and gap them) If that does not work change out all questionable parts in the secondary (coil onward ) I will be surprised if that does not fix it.
What you are discribing are plugs miss fireing under load,, or a weak coil. These are the things in the secondary system.You say the wires are new? Maybe I missed that.
Old 05-12-2008, 04:38 PM
I'm a loser, baby.
oregonmon's Avatar
No wires are not new but the mechanic said they looked newer. But even that was a few thousand miles ago.
I think I will do what you are saying because it seems that most people are pointing that direction. Thanks.
1979 911 SC
Old 05-12-2008, 06:26 PM
