Another O2 Sensor Light Question
My Oxygen Sensor Light came on today. Pulled the speedometer to reset the mileage counter and don't see a reset as described in Bentley Manual and in other posts. Any ideas???
Thanks in advance. Rick
This is the speedometer you are holding there. You should see a box behind it in the open hole where you pulled out the speedo. The reset knob is located on that box.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
I figured it out. Reread one of superman's posts and followed the wires around. The box sits about 8" behind the speedometer. I was able to reset the button with a chopstick, which is a permanent tool in tool in my toolbox. I also use chopsticks to plug the distributor's vacuum lines when setting the timing.
Rick
Ischmitz,
Thanks for the reply. Rick |
