tangerine911S's Avatar
All the jacking points??
I feel kinda stupid as I know this has probably been discussed ad nauseam but I can't find information about jacking points and procedure for an early car (if there is a difference). My search function is not producing relevant results. For the rear I remember using a block of wood or newspaper under the sump plate but I don't know the proper jack location for the front or for the side. I have reservations about using the factory jack pad under the rocker as I'm not 100% sure about the integrity of that area. Some pictures or links to other threads would help. Thanks!
Old 05-16-2008, 10:27 AM
AutoBahned
RWebb's Avatar
you can use a 2x4 to jack up the front - it goes all the way across from 1 torsion bar attachment point to the other
I posted pics on how to do it at one time - if you've never done it before you should see some pics first - esp. with a valuable '72 S!!
what search terms are you using? that is the way to find the details
Old 05-16-2008, 10:39 AM
HarryD's Avatar
SEARCH is your friend. Try the terms jack points.
Check post #22 of this thread: http://forums.pelicanparts.com/porsche-911-technical-forum/253672-lifting-points-post2263696.html?highlight=jack+points#post2263696
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-16-2008, 11:11 AM
Brian,
whatever you do, go slowly. A lot of guys drive their 911 up onto planks of wood first, then use the increased height to get a jack under the car. I believe on yours there is a fabricated steel cross member betweent the a arm rear mounting points. I think these could be used for jackstands. I use two low profile hydraulic jacks at the front a arm mounting points. Dont place a jack under the a arm itself, you might bend or cause the a arms to bind.
Old 05-16-2008, 11:32 AM
Thanks guys, some good info there. Apparently my search button doesn't work as well as others because I searched for many things before and am left with completely irrelevant threads. Searching by posts instead of threads seems to work alright though.
Old 05-16-2008, 02:24 PM
AutoBahned
RWebb's Avatar
use a Google site search...
stands should go at the points where the seam curves tightly (radius ~~ 10 cm) - Bill Verburg posted a diagram of the area
go ahead and mark what you are going to put where and post the pic before you lift the car to get more info
and... how about some pics of that '72??
Old 05-16-2008, 03:33 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 05-16-2008, 06:23 PM
HarryD's Avatar
Originally Posted by Icemaster View Post
The factory jack points on the side of the car are also good to use. You can lift the entire side and then place jack stands where you need them.
Per Bill Verburg (post 22 from my reply above) , the spots with the x'es are good points to put your jack stands. .
Harry
2020 MB E350 4Matic
Old 05-16-2008, 07:52 PM
Is it necessary that I use that jack pads that slide into the slot under the rocker if i jack up one side?
Old 05-16-2008, 07:59 PM
HarryD's Avatar
I would not do it any other way.
Harry
2020 MB E350 4Matic
Old 05-16-2008, 08:03 PM
