Mad Aussie Porsche nut
I just bought a set of 40 Pmo's from a fellow pelican. Can anyone suggest jets etc for a 2.7 S Cis euro engine with early exhaust and 2 in 2 out muffler ?
Wer bremst verliert
57 idles
180 airs 135 or 140 mains
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Thanks John,
Would that be with 32 or 34 venturi ? |
CIS cam ?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Call or fax Richard at PMO. Do whatever he suggests.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
My setup was computed by Steve Weiner and Richard Parr.
I am running stock cams and stock pistons. Only mods on the motor is the heads which were fly cut for a slight bump on compression. I believe the previous owner left the ports the same. 40mm bodies 34mm venturies 135 mains F11 Emulsion tubes 55 Idle jets 130 idle air jets 190 Air corrections jets I believe I am running a little rich as my motor runs about 10 degrees cooler now than with the CIS. I still need to get the car dynoed and check the AFR under load to find out for sure. This setup seems to pull hard and the motor breaths real healthy.
'75 911S Silver Anniversary #164(Formerly JTO's) Rebuilt 2.7 with full ARP, 9:1 CR. SSI, GHL, ER polybronze bushings, finned oil lines. Lowered and corner balanced. CIS retired, now PMOs! '65 912 slate gray sunroof (driving project) |
Wer bremst verliert
Mine were 34 venturies. I'm at sea level.
Bland
I just went through this with Richard at PMO last week. You want 34 venturis, 140 mains, F2 emulsion tubes, 55 idles, 180 air correctors for a street car or 36 venturis and 150 mains for a more track oriented car.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
