Mad Aussie Porsche nut
madpcar's Avatar
Question PMO Set up for a 2.7 ?
I just bought a set of 40 Pmo's from a fellow pelican. Can anyone suggest jets etc for a 2.7 S Cis euro engine with early exhaust and 2 in 2 out muffler ?
Old 05-19-2008, 05:00 PM
Wer bremst verliert
JohnJL's Avatar
57 idles
180 airs
135 or 140 mains
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 05-19-2008, 05:19 PM
madpcar's Avatar
Thanks John,
Would that be with 32 or 34 venturi ?
Old 05-20-2008, 05:53 PM
CIS cam ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-20-2008, 06:05 PM
moneymanager's Avatar
Call or fax Richard at PMO. Do whatever he suggests.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 05-20-2008, 08:17 PM
ael911's Avatar
My setup was computed by Steve Weiner and Richard Parr.
I am running stock cams and stock pistons. Only mods on the motor is the heads which were
fly cut for a slight bump on compression. I believe the previous owner left the ports
the same.
40mm bodies
34mm venturies
135 mains
F11 Emulsion tubes
55 Idle jets
130 idle air jets
190 Air corrections jets
I believe I am running a little rich as my motor runs about 10 degrees cooler now than with the
CIS. I still need to get the car dynoed and check the AFR under load to find out for sure. This setup seems to pull hard and the motor breaths real healthy.
'75 911S Silver Anniversary #164(Formerly JTO's)
Rebuilt 2.7 with full ARP, 9:1 CR.
SSI, GHL, ER polybronze bushings, finned oil lines.
Lowered and corner balanced. CIS retired, now PMOs!
'65 912 slate gray sunroof (driving project)
Old 05-20-2008, 08:39 PM
Wer bremst verliert
JohnJL's Avatar
Mine were 34 venturies. I'm at sea level.
Old 05-21-2008, 04:53 AM
Bland
unclebilly's Avatar
I just went through this with Richard at PMO last week. You want 34 venturis, 140 mains, F2 emulsion tubes, 55 idles, 180 air correctors for a street car or 36 venturis and 150 mains for a more track oriented car.
Old 05-21-2008, 07:48 AM
