What crank options do I have for a 3.0L case?
I posted this over at the engine rebuild forum but there doesn't seem to be much action there... What crank options do I have for a 3.0L case? I just want to know what my options are before I start looking for parts and building this thing
![]() Thanks Kevin
'73 914 2.0L |
Hi!
It's in Wayne's book engine rebuild book. Something about bigger P/C's and turning it into a 3.2 short stroke. You can also put in 964 cams. I know that doesn't address the crank.
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
I just don't want to short change myself on the crank, at least I can go with a 3.2 crank and get 3.4L out of it.Kevin
'73 914 2.0L |
MBruns for President
with the right machining on a 3.0 case you can go up to a 3.6 crank and a gt3 oil pump with a little work anyway.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Somatic Negative Optimist
With a SS 3.2 (98 mm P/C's) no machining required but you'll need the crank from a 3.0 (70.4 mm stroke) I believe you cannot use the 74.4 mm crank from a 3.2 on 98 mm P/C's. ??
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
I've got a 3.2 crank if you ned one
![]() AM
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
Guys,
Let’s be a little more specific. If we start with a 3.0 911SC (’78-’83) case, what are the options? What are the modifications to use the later, longer stroke crank? Is it possible? What mods? What with a Turbo 3.3 case or a Carrera 3.0 case? Lots of unanswered questions here. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
A 3.6L crank has a stroke of 76.4mm, with 98mm pistons that is only 3458cc (3.5L) I am not sure if I want to punch out my case and heads to accept the 100mm pistons and cylinders and make a 3.6, than I might as well find a core 3.6L. But then I start all over again....might as well go to 3.8 lol, that'll be the next build ![]() Someone posted on this thread on the engine rebuild forum that a 3.6 crank fits with no mods, but if I am only using 98mm P/C's the displacement increase is marginal over the 3.2 crank. The goal is to build a fun reliable engine using as many of the 3.0L parts that I already have, after some research a 3.2 crank and 98mm P/C's I think is the best setup. Thanks Kevin
'73 914 2.0L |
Hi Andrew, I would be interested in the crank, is standard? Do you have the rods too?
Thanks Kevin
'73 914 2.0L |
I went with a 3.2 crank + 100mm P/Cs to get to 3.5. The engine has lots of power, but my one complaint is that it doesn't "rev" as fast as a 3.0 with carbs and headers or a 2.7 with headers. Personally, I find the rev-happy 911 engines to be alot of fun. If I were to do it all over, I would go with a high compression 3.2 short stroke (3.0 crank + 98mm P/Cs).
my 3.4 (build is detailed in the engine rebuild form) 98mm P/C is very rev happy. Has light weight internals and Ti retainers and mod "S" cams all running through 48mm throttles and headers...... made 285 at the wheels..... amazingly quick throttle response.
Throttle response is more a factor of the intake type than anything. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Hi Kevin - I do have the crank with the rods still on it - I was going to take the rods off and take the crank to my machine shop to make sure it measures out ok.
Regards, Andrew M
