<insert witty title here>
Something's sapping my power
This is an issue that's been dogging me for a while now, and I'm getting sick of throwing time and money at the wrong things.
I'm getting a notable loss of power throughout the rpm band, but only when I've been driving the car hard at the track - it never crops up on the street. It starts just as my tires are getting warm, so after a lap or so. The car still accelerates and there's no stumbling or unevenness across the power band, but it feels like I'm down to maybe 75hp or something. The engine sounds perfectly normal, and if I pit and let the car cool down for 10 or 15 minutes, it'll drive normally for a lap or 2. The power lack is such that I can barely hold a steady speed on an uphill straightaway (Mosport) with the pedal to the floor, 3rd gear, 5000rpm. Car is a 72 911T with original Zenith carbs, carbs were rebuilt 2 years ago (by me) and tuned professionally, brand new MSD coil, replaced CD box with blue Permatune used box, new plugs and plug wires summer of 2006, new points last summer, timing, advance, etc. all set by the shop when the carbs were tuned. I've floated this problem here on Pelican before, but that was before the coil and CD box were changed, and that didn't fix it, even at a track day in cold weather (10C/50F). The only thing that gets rid of it is letting the car sit for 10 or 15 minutes. And again, this problem has never came up on the street, only at the track. Any thoughts? My next step if I can't fix it will be to just take it into the shop for diagnosis, which I know will hurt my chequebook significantly! Thanks! Chris
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
others smarter than I will be more helpful but I'm betting it is in the fuel system. -that's all I've got.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
That came up before, but that doesn't explain the problem only occurring when hot and the first lap or 2 being normal. FWIW, I did go to an empty dead end one day last year, and drove around like I was doing an autocross, to really swish the gas around to see if there was any starvation issue or anything - no change.
Max Sluiter
I am not an expert, but here is my thought:
I have heard of fuel pumps delivering full pressure and volume at cool temperatures like at startup and for a few minutes, then when the going gets serious, they show their weakness. Maybe heat soak is overwhelming it and you are depleating the reserve of fuel in the carbs. You then run on the reduced fuel flow the pump gives while warm, which is nt enough for tack use. Hope this helps. I enjoyed your transaxle project.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
I've had a similar problem before but on a Fiat with a weber carb. It turned out to be a speck of dirt somewhere in the carb. I would never blame the carb because I had just rebuilt it as well. The problem would only manifest itself when the car was nice and hot. As soon as it cooled down, the problem would dissapear. Problem only went away once I blew every single orifice of the carb with an air compressor after soaking in carb cleaner overnight...
95 Carrera 4 Black/Black Coupe, Row M030, Bilstein HD Past - 89 911 3.2 silver cab |
(as to the quoted post) Howsabout a fuel pressure check when she's good and toasty? Just for good measure? No Pro here either..sounds like something heat related (way too generic, I know)...starting with the fuel pressure (while toasty) seems easy enough. I'm sure the pros will grab hold of this thread.....speaking of toasted elements. ...standby for news. Best,
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Do you have any data on engine temps? I say this because there is a remote chance that you're running lean at the top end and the motor is wanting to seize. Have you checked the plugs after such a run? I know you're not supposed to pull them hot, but you need some data on this. A cylinder head temp sensor would be good, too. Oil temps are behind in terms of real time data. If you could somehow see into the exhaust ports, you'd have an idea of the mixture.
Maybe you can find some temperature paint for the headers right at the flanges. At 1200 degrees, you're in a dangerous zone. I sure wouldn't go back to the track until you know about this and I hope this is not the problem. Maybe it's ignition, like that used Permatune |
Tree-Hugging Member
After reading the title of your thread I've had to resist the urge to quote lines from Dr. Strangelove.
Anyway, I'm with the fuel/lean group; it doesn't sound like spark or air. Fuse/Relay hot? Fuse contacts/wires corroded or broken? Pump electrical contacts corroded or broken? Plugs look lean? Fuel pump hot? Fuel filter clogged? Crimp in fuel line? Crud in the tank - is the filter sock in the tank slightly clogged? Fuel pump flow rate cold vs. hot? Bet it's in there somewhere.
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ |
Is the fuel tank venting ok?
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
In line with Milt's suggestions, you might also look under the fan shroud to check for mouse nests blocking cooling to one of the cylinders.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
This is a long shot, but does the car seem unusually quiet when it loses power? Sometimes loose stuff in the muffler (like dogfood stashed by rats) can occlude the outlets when a car is driven hard.
regards Phil |
Tree-Hugging Member
911mot also has a good poing; berettafan has a thread on that which you might find interesting:
fuel tank vent system is capped; may be source of my fuel starvation?
Okay, I'm absolutely no expert (the only racing I do at my age is to the bathroom after a spicey dinner) but I'm going to offer something completely away from the above posts.
You stated, "It starts just as my tires are getting warm, so after a lap or so. The car still accelerates and there's no stumbling or unevenness across the power band..." Since the engine seems to be running/sounding correct, could your "lack of power" be the brakes binding--something that might happen after a few laps of pedal action? Then, after a period of rest, the pistons retract and all "power" is returned until more brake action binds them again. Just another possibility and it might be easy to verify
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 05-29-2008 at 06:09 PM.. |
up the fuel pressure for racing. route a fuel pressure gauge inside the car so you can see what's going on. tap it in just before the carbs.
Hey all, thanks so far for all the suggestions. Couple things I forgot to mention:
1. new fuel pump and filter 2 years ago, rerouted to the front suspension pan, rather than the original near the rear left wheel. So highly unlikely it's the filter at the pump or the pump itself. Most of the lines have been replaced recently, though not all. 2. New muffler last summer - Bursch sport. Milt, no, I have no data on engine temps when hot, other than what the guage tells me. I haven't checked the plugs in a while, but I can pull them to at least diagnose them. Something just occurred to me - could improperly gapped plugs be the cause? When I replaced the plugs 2 years ago the shop said the gap was set right at the factory, but it's possible that could be a mistake, or maybe gapped for MFI, etc. Can you pull them hot? Wouldn't they be hot enough to melt the rubber in the plug socket? It's possible that both the Permatune and original Bosch CD box are flakey, in exactly the same way, because swapping them out makes no difference at all, but that doesn't sound too likely, does it? I have no idea if the fuel tank is venting properly - never checked that out, but I will. Sounds simple enough to check. initial, something along those lines has crossed my mind before, and if I get a chance, I'll see if I can borrow another set of carbs to test out, and see if that makes any difference. FWIW, I have had someone else press the gas pedal down and I've watched to make sure each throat is fully opening (with the car not running, of course).
LJ - interesting theory. How could I test it?
JW - What if the fuel pump isn't adjustable? I guess I'd have to replace it with an adjustable one? And one easier to access - I'd have to pull the suspension pan to access it as it is now - not something I'd be wanting to do every track day.
Don't know for sure, but if that's the cause you can bet the calipers will be extremely hot--more so than on a car that doesn't have binding brakes.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Retired Member
I had a permatune in my car. My suggestion would be to replace it with an MSD system or stock CDI unit. My old permatune would act erratically when the car got hot (track time).
Maybe richen up the mixture. It may help the car run cooler on the track.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
Lifted from the Net: "Determining how hot your brakes are getting is relatively simple. You can apply special heat-sensitive paint to your brake rotors that will fade when a specific temperature has been reached. Most brake manufacturers sell the paint in sets, with different colors for specific temperatures. Simply apply the special paint to small sections of the outside edge of the disc (not the disc face). After a run, pull the wheel and inspect the rotor. The hottest section that has faded paint shows the range you've exceeded, and the next section in the range that has paint that isn't faded shows you what you are still below." Quote:
Max Sluiter
Maybe it's a transaxle bearing going out
![]() Just kidding ![]() ![]() ![]() You don't think it could be something as simple as vapor lock?
