Mad scientist
Peter Bull's Avatar
An alternative anti roll bar setup
A year or so ago I got a set of custom valved Leda coilovers. The springs that came with the coilovers were somewhat stiffer than what is achievable with t-bars, so I knew I had to get new anti roll bars as well. Although there are many good ARB-sets available, all of them use the through the front tub/wheel well design, which I don't feel comfortable with. Therefore I designed a setup myself. The parts were available as a kit from Sellholm Tuning in Sweden. So all I had to do was weld up the tubes, make some brackets and fit it into the car. Well, it wasn't exactly that easy, and it took a while to complete, but here's the result.
Front setup, as seen from the front
Front setup, as seen from the rear
Rear setup
The rear brackets are a little too close to the ground, and I'm not entirely happy with the bearing solution. But hopefully that will be ironed out after a little running in period.
/Peter
'84 911 Carrera
'91 928 S4
You can't make a racehorse out of a bull, but you can make an awfully fast bull.
Old 06-02-2008, 11:26 AM
aftermath's Avatar
why cant you use existing roll bars, like adjustable ones from elephant racing if your using stiffer coil overs? I plan to buy a coil over kit and new suspension down the road.
theamsoilguy@hotmail.com
Old 06-02-2008, 11:33 AM
Max Sluiter
Flieger's Avatar
Why do you need stiffer bars at all if you have stiffer springs? The stiffer springs will reduce roll by themselves.
Old 06-02-2008, 11:42 AM
Mad scientist
Peter Bull's Avatar
You can, but as I said I don't like the through the tub/wheel well setup where the front ARB is mounted in the sheet metal in the wheel well.
If you want the possibility to adjust the behavior of the car with the ARBs, they have to contribute noticeably to the roll stiffness of the car. Therefore; if you use stiff springs you need stiff ARBs.
/Peter
'84 911 Carrera
'91 928 S4
Old 06-02-2008, 12:01 PM
Monkey Butt Forespin
84_Carrera's Avatar
Yep, that design is similar to typical modern car swaybar endlinks. Attach at the strut & end of sway. I bet over time you'll really hear the Heim'd links vs. something that's a sealed unit.
Looks nice for the work though.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 06-02-2008, 01:05 PM
lateapex911's Avatar
That is certainly a very sophisticated setup.
I like how the front bar actually will produce a variable rate depending on steering angle. Less effect at lower speeds. Not often seen, very slick.
And the use of blade arms means the stiffness adjustments won't affect the geometry. Very nice.
where did you source your components?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 06-02-2008, 01:18 PM
Mad scientist
Peter Bull's Avatar
Thanks. There are some rubber shims available to seal the rod ends that I'll fit once I find a place to buy them. Hopefully that will extend the service life a little, but I reckon I have to change the rod ends every now and then.
Thanks, I sourced most of the parts from a company in Sweden called Sellholm Tuning. The brackets on the front coilover struts I had machined from aluminum, the front mounts were made from some flat bar, and the rear mounts were welded from some steel U profile.
/Peter
'84 911 Carrera
'91 928 S4
Old 06-02-2008, 02:34 PM
I don't see the cable connection to rotate the bladed arm.
Sherwood
Old 06-02-2008, 02:36 PM
Mad scientist
Peter Bull's Avatar
Sherwood
I'm afraid I don't have one. I don't feel the need for that. Yet.
/Peter
'84 911 Carrera
'91 928 S4
Old 06-02-2008, 02:42 PM
Less brakes, more gas!
euro911sc's Avatar
Blade arms also mean infinite adjust ability instead of the 5-6 holes usually found... Nice work. I'm sure it is prohibitively expensive to ship to the US, but I'll check out the web site
-michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 06-02-2008, 06:30 PM
euro911sc's Avatar
hehehe always a fun problem when the web site is in a different language with lots of funny marks all over the letters
-m
Michael
'13 Cayenne GTS
Old 06-02-2008, 06:31 PM
Mad scientist
Peter Bull's Avatar
-michael
They are a little tricky to adjust. When the blades are on edge; turning them just a small angle results in a relatively large change in stiffness, and when they lay flat it is the opposite.
-m
Funny marks? I don't see any funny marks
/Peter
'84 911 Carrera
'91 928 S4
Old 06-03-2008, 09:38 AM
