I'm a loser, baby.
oregonmon's Avatar
"How to" change plugs, wires, cap, rotor?
Hey all,
I am trying to resolve a miss or rough running SC under load and am going to change plugs, wires, cap and rotor. All Bosch OEM products. As I have never does this job and need a lot of help, does anyone have a link to a good how to or feel like giving me one here. I did see there is a tech article on Pelican for Magnecor, I imagine it would be the same. This surely has been covered numerous times right?
Hope the spring is treating you and your driving addiction well.
1979 911 SC
Old 06-04-2008, 12:58 PM
old man neri's Avatar
Well my tips are:
1) Get a bently manual and/or 101 projects for your 911
2) Use the factory spark plug tool
3) Change your wires one at a time so you don't cross anything
4) Take your time with the plugs and don't force anything, cross threading a plug is a nightmare
-matt
Old 06-04-2008, 01:59 PM
What the ?
glewis80SC's Avatar
Bentley manual for sure!!! Be patient when doing the plugs, they can be a pain getting in and out.
SCWDP 73
1980 SC
Harley Davidson Road King
9/11/01 FDNY/343 Never Forget!
Old 06-04-2008, 02:40 PM
Yes I agree with the first two posters.
I noticed that Amazon has the manual. One of the alternatives that I like (forgot who's tip this is, so sorry) is to thread the spark plug with a rubber fuel hose. That idea sounds good, but I haven't tried it. Whatever you do, don't try to change them while the engine is hot.
Did you check your timing advance too?
Old 06-04-2008, 03:45 PM
Senior Member
Superman's Avatar
The distributor cap has a "key". That is, it only fits onto the distributor body one way. There is a notch in the rim of the distributor body that engages with the "key" in the rim of the cap. Other than this, and the advice of using the factory spark plug tool, should be enough for you. Take your time. If you stay focused, it is what we call a "one beer" job.
Mocha 1978 911SC. "Coco"
Old 06-04-2008, 04:14 PM
dshepp806's Avatar
Be sure to get a good seat on the plug wires.
I guess most install the plugs dry (I think the book states this). I've taken to some advice I rx'd from Pete Zimmerman, making very, very light use of L grease on my threads.
You want to ensure proper torque on the plugs, as well....22 foot pounds.
Spark plug gap, of your choosing based on spark plug selection.
What Superman said,..if not positioned properly, you stand a chance of cracking the distributor when you latch it down.....(something I did way, way back).
Have a nice magnet nearby, just in case you drop a plug into netherland.
Take LOTSA time, ensuring not to crossthread the plug (what glewis80SC said)
Take special care to route the wires nicely,...no rubbing/touching where it shouldn't.
Make sure the rubber cover (?) at the spark plug end of ignition wires is seated down nicely.
These points applicable to my 89.
Best of luck,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-04-2008, 04:38 PM
Senior Member
Superman's Avatar
When the crush washer at the base of a spark plug finishes crushing (you dan feel it crush, and then you can feel it get tight once it has crushed completely), then you are at the correct torque. Spark plugs are commonly over-torqued. With aluminum heads, over-torquing spark plugs is.........a mistake.
Old 06-04-2008, 04:45 PM
HarryD's Avatar
Ryan,
This is not much harder than changing your oil. The above advice is very good.
Tools
-Factory Spark plug wrench
-Dielectric Grease
-Marker
Procedure
1-Remove cap by unhooking the two clips that are 180 degress apart. Mark the wire closest to the fan housing (more on this later). Lift cap off.
2-Note position of rotor and pull rotor out by pulling straight up.
3-You will see a hole under the shaft that the rotor is on and a felt plug. Use a pick (something like what a dentist uses to clean your teeth-you wife may be able to get you a nice sharp one from work) to remove the plug and put a few drops of motor oil into the hole. Replace plug.
4-Put new rotor onto shaft. It is keyed and can only go on one way. Remeber how the old one was oriented. Be sure it is fully seated.
5-Take new cap and place over rotor. It is also keyed and can only go on one way.
6-Remove the wire that you marked in the first step from the old cap. Find the other end and remove it from the spark plug.
7-Use the factory tool to remove the old spark plug.
8-Install the new spark plug. Start by hand. It should go in pretty easy for a few turns (be sure it is not crossthreaded). Once started, turn until you feel the spark plug seat and give it a firm turn until you can feel the washer begin to give (seat). You do not need to be a gorilla.
9-Find the new wire that matches you old wire in length. Smear a dab of dielectric grease in the inside of each boot. Route the wire like the old wire was routed.
10-Attach the wire to the sprk plug. Press until you feel a slight click.
11-Attach the other end of the wire to the distributor post that corresponds to the old wire you took the old one off of. (If this is the first one, it is the one closest to the fan housing). You may need to "burp" the air out of the boot to get it fully seated.
12-Repeat steps 6 to 11 until all six wires are replaced.
13-Replace the wire from the Coil to the center of the Distributor.
You are done!
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-04-2008, 05:17 PM
Member 911 Anonymous
DRACO A5OG's Avatar
If I may add,
Engine must be cold.
If you have an AC, you need to remove the AC Compressor to gain easier access to the plugs, wires and clamps/harnesses. Once you have all the wires where you want them then put on the harnesses and replace the AC Compressor.
Also, I would get some copper anit-sieze on the threads only on the new plugs. Do not over tighten, what ever you do. If it is dificult to screw on the plugs you probably cross threaded it, start again. Note the angle & Remember, you need to hear a click when you install the rubber plugs.
Take your time and enjoy the process.
'85 Carrera Targa
PCA/POC
Old 06-04-2008, 05:44 PM
boxster03's Avatar
now that is excellent info. good job guys.
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 06-04-2008, 06:07 PM
I like this Hazet.
the plug goes right into the head. No way of missing. Great for avoiding cross threading plugs.
I think a complete newbie should have someone around who has at least a little experience.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-04-2008, 06:29 PM
Fahren mit dem Wind.
mhackney's Avatar
Hey Ronin, I was looking for one of those! Found it at http://www.samstagsales.com/hazet.htm
Hazet #2505-2
Another day, another tool.
Cheers,
Michael
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net)
Caregiver to:
1983 911 SC Cabriolet - Fahern mit dem Wind.
(Moss Green Metallic over Champagne and Brown Leather)
Old 06-04-2008, 07:56 PM
the more you use it the better it gets.
from Mike's site
2505-2 Socket,
Spark Plug 3/8" dr
Expanding Spark Plug Socket,
13/16" (20.8mm) .
With a rubber insert to hold the plug. It is made with Chrome-Vanadium steel and mat chrome plated.
Push the release pin and this socket will adjust from 137.5mm to 157.5mm to 197.5mm.
HAZET suggests you use a model 8816GK flex head ratchet with this socket to get the most benefit.
$50.53
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-04-2008, 08:46 PM
I'm a loser, baby.
oregonmon's Avatar
Thanks guys for the replies and especially Harry. Maybe see you on Sunday for autocross. Does everyone remove their A/C? Is it really necessary, the less parts I mess with the better I'm sure.
1979 911 SC
Old 06-04-2008, 09:21 PM
DRACO A5OG's Avatar
You can leave it on but I hope you have skinny arms but guiding the wires under it will be a PITA.
It really is no big deal to remove the Compressor.At first I was a bit concerned but just remember not to over torque and insure 1/2 movement at the center of the belt. Plus you may want to replace the fan belt and AC belt WYIT (While Your In There)
'85 Carrera Targa
PCA/POC
Old 06-04-2008, 09:26 PM
No need to disconnect the hoses. I think most people when they change their plugs and wires are also doing an oil change and valve adjust so the AC is already out of the way. If you do everything at once it saves time I think. Also look at your fuel filter and air filter if you are changing your plugs/rotor.
Old 06-05-2008, 07:24 AM
mhackney's Avatar
Absolutely DO NOT disconnect the AC hoses! All you need to do is remove the 3 AC Compressor mounting bolts. Put a big towel (folded several times) or better yet, an 18" square of 1/2" closed cell foam on the right fender and carefully lay the compressor on it without kinking the hoses.
Cheers
Michael
Caregiver to:
Old 06-05-2008, 07:31 AM
And, according to several Porsche wrenches - do NOT use Bosch PLATINUM plugs...
Old 06-05-2008, 08:00 AM
I'm a loser, baby.
oregonmon's Avatar
Yeah, when I bought the car and my wrench changed the plugs from the PO, that's what they were and he recommended no platinum plugs.
1979 911 SC
Old 06-05-2008, 08:16 AM
gtc gtc is offline
abides.
gtc's Avatar
I don't think you need the factory plug wrench. I use a craftsman 13/16" spark plug socket and it works fine. The key is to have a socket that holds the plug firmly - it's a pain if you drop it inside of the valve cover. You'll need a few different length extensions.
I buy the $2 NGK plugs at Autozone (pelican has them for $3.50). They're cheaper, work better, and last longer than the bosch platinums that came with my car.
Remember to check the plug gaps.
Graham
1984 Carrera Targa
Old 06-05-2008, 11:46 AM
