Need a 901 pic please
Things don't seem right as I try to adjust my clutch on my 901 transmission. I have installed engine and trans from diffterent cars and think something I may be missing something. I took the car for a few rides and on my last trip the cable seemed to come out of adjustment (had to limp home in 1st gear).
I am particularly interested in how it attaches to the shift fork and the adustment points.
Old 06-04-2008, 05:07 PM
AutoBahned
RWebb's Avatar
search on my name + trans for a variety of them
AND.... are you sure it is a 901 and not a 911?? post the year of the car, and the type ID on the trans.
Old 06-04-2008, 05:13 PM
boxster03's Avatar
you know a 901 was actually the first model of the 911. anyone with a picture of the 1964 french car show car for this guy
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 06-04-2008, 06:09 PM
RETIRED
Joe Bob's Avatar
901 is the trans type that has the first gear over and back in the same plane as third and fifth. Reverse, second and fourth on top....
R 2 4
1 3 5
2012 ML350 3.0 Turbo Diesel
Old 06-04-2008, 07:03 PM
Anybody? It would help a ton. Thanks
RWebb I searched your posts and couldn't find the picture I needed. Yes, I am sure it is a 901.
Old 06-05-2008, 08:47 AM
RETIRED
Joe Bob's Avatar
I assume it has a cable with a locking or double nut on the end? Can you adjust it back so that the clutch works? If no locking nut get one...it's just moving....
Or does the adjustment have no more threads on the cable? IF THAT is the case, either the cable is too long or the tube in the tunnel is broken loose from the welds.
Old 06-05-2008, 08:51 AM
Well, I see 2 problems.
1. The method of how the cable is locked. The adjusting nut looks odd, almost like it was modified or incorrect altogether. It is bullet shaped, can't find a part like this in any catalog.
2. Cable seems too long by 2-3 inches or so. Actually rubs on my the hard oil line that goes under bellhousing. I assume that this rubbing is what brought clutch out of adjustment.
Old 06-05-2008, 09:11 AM
AutoBahned
RWebb's Avatar
not really sure what you want
try this:
Old 06-05-2008, 02:03 PM
AutoBahned
RWebb's Avatar
explain what you mean by "Shift fork" and maybe I can find you a better pic or diagram
Old 06-05-2008, 02:08 PM
Otto's Avatar
That is a picture of a 911 transmission, cira 1970 and 1971 only.
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 06-05-2008, 02:53 PM
AutoBahned
RWebb's Avatar
yes - the pivot is ~1 cm offset from a 901; and the pivot of the shift fork differs slightly
Old 06-05-2008, 04:12 PM
I meant clutch release fork. I would like to see a pic of a 901 transmission with the clutch cable mounted. I am trying to figure if my cable is out of spec, the hardware is wrong, or maybe the routing was incorrect
Old 06-05-2008, 09:58 PM
AutoBahned
RWebb's Avatar
a pic of the cable attached to the other end of the throw out arm?? that is the arm pictured above
I do not have a stock setup to show you -- for that you'll have to search
Here is the 911 trans. again - it is equipped with a 901 style setup - note how the cable is mounted
you probably need to post pics of your setup...
Old 06-05-2008, 10:25 PM
1-6-2-4-3-5-1-6-2-4-3-...
pope's Avatar
Since I'm getting mixed up on the transmission codes as I always thought I had a 901, here's my serial no:
Is this a 901 or a 911 then?
ttw, I'm posting a few pix I have of the clutch cable near the transmission for your convenience:
'70 911E Coupe, Webers 40IDA
Old 06-06-2008, 01:11 AM
Bill Verburg's Avatar
The 901 was used thrue '69, it has a sand cast al. case & 215mm clutch.
the 911 was a stronger development of the 901 used for '70-71, it has a die cast al case(later changed to Mg & 225mm clutch
915 was introduced for '72 w/ the new shift pattern, 225mm clutch & mg case
Bill Verburg
Old 06-06-2008, 04:48 AM
JWest's Avatar
Not quite right on the material changover.
The magnesium case came out in mid-production on the '69 901 still using the older style push clutch.
James
JWest Engineering
Old 06-06-2008, 06:54 AM
Poor-sche Lover's Avatar
Isn't the 901 what they used in the 914's? Maybe search there. Mine isn't available for pictures right now.
Old 06-06-2008, 07:47 AM
AFAIK, the '69 transmission change was from sand cast al. to die cast al.
The change from 215mmpull clutch to 225mm push clutch corresponded to the introduction of the 2.2L engines for MY70&71 & the trans. case changed from al to mg sometime in this series production(C series)
the '69 change(B series cars) from sand cast al. to die cast mg was for the crankcase not the trans case
Bill Verburg
Old 06-06-2008, 07:54 AM
JWest's Avatar
I've got '69 magnesium case trans sitting a few feet from me. 901/13 from a '69E which also had a magnesium crankcase.
James
JWest Engineering
Old 06-06-2008, 08:09 AM
a pic , please
Bill Verburg
Old 06-06-2008, 08:31 AM
