Bill is Dead.
My thought also.
It's easy to miss the bearing groove and get the fork bound behind it.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
<insert witty title here>
It's definitely not the detents, nor is it stuck in gear. I can say this for sure, because I started a thread entitled "Grrr, *$&#ing detents!" in which I made sure I got it right!
![]() The car rolls freely in neutral, does NOT roll when it's in gear, and DOES roll freely when in gear, with the clutch in, which also confirms that yes, I did make sure the clutch TO fork was properly in the groove in the TO bearing. It wasn't at first, and luckily I read something here on Pelican before I reinstalled the engine - I pulled the engine back off the tranny and reattached them, making sure the fork was in the groove, and confirmed by looking through the little "window" in the top of the tranny to confirm. vreference, no, there's no reason to assume any mechanical issue with the motor - it was running fine before removal, and it wasn't opened at all. The "grinding" I heard was not grating nor loud enough to really cause me concern. What I think it was was just simply the noise of the transmission gears moving and turning, without the accompanying sound of the engine running - imagine having the car jacked up and in gear and turning the wheels so all the innards of the tranny are moving - that's more like what it sounded like. I'm going to pull the starter this morning, as soon as I get some breakfast and go buy a 10mm allen socket (was using borrowed tools when I dropped the engine). What about my question about the ground strap bolt on the tranny - does it matter which bolt/nut?
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Can you turn the motor over by hand? (pulley wrench on the fan and pressing the belt on the RH side to take up slack) (sorry if this has been asked - I just skimmed the replies. Everyone is pointing in this direction and it was amongst my first thoughts, too)
Friend of Warren
No shiit. This is the first thing I would be trying before I pulled the starter.
Kurt V No more Porsches, but a revolving number of motorcycles. |
GAFB
I seem to be late to the party but the first thing I thought of when you mentioned that this is a '72, is that the cylinders might be full of oil. Was the engine spun over before putting everything back together? Don't bump the car again until you are sure the engine spins with the clutch thrown out (might need a helper or chock).
Several BMWs |
Ok, engine turns over by hand no problem. It's in gear, and the car lurched forward a bit when I turned the pulley. Here's a short video (2.5MB):
http://cledroit.googlepages.com/MVI_5899.AVI If you ignore the sound of the fan belt slightly slipping on the pulley, you can hear the transmission gears turning, and if you watch the garage wall in the background, on the 2nd turn you can see the car move (the camera was sitting on the engine shelf. The engine oil was drained before we removed the engine, of course, but I can't say I remember for certain if we spun the engine at all before reinstalling - I don't remember doing so, but I could be wrong. Should I retry turning the engine over with the clutch pushed in? edit: BTW, just to confirm, I did indeed watch the lower pulley to make sure it was turning, and that it wasn't just the fan belt slipping on the lower pulley.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster Last edited by Christien; 06-05-2008 at 06:17 AM.. |
Ok, I put a chuck under the wheel and put it in neutral (I'm home alone right now and don't have anything heavy enough to hold the clutch pedal down). The motor turned very easily by hand with minimal pressure on the fan belt, and now the transmission noise is much clearer. Here's another short video - have a listen and tell me if this means anything:
http://cledroit.googlepages.com/MVI_5900.AVI (1.75MB)
GAFB
OK good. Engine is not full of oil and your flywheel is not blocked. Time to check out the starter. Before doing that though, I'd check the battery to ensure it is putting out enough juice. Yep, I know it is new. Also make sure your cables are securely fastened and in good condition, especially the ground. Also check your ground strap on the transmission. Did you paint your crossmember? No it doesn't matter really which bolt you use but the strap should be in good condition and the contact points should be nice and clean. I'd check all that before going to the effort of removing the starter.
Oh...is your clutch properly adjusted? What happens when you try starting in neutral.
Several BMWs |
All the grounds I removed were significantly cleaned up before reinstalling the engine and tranny, especially the ground strap, though I'll do it again. Not only is it a new battery, I've tried it with another battery from another car known to be good, plus I've tried jumping it from 2 other cars (not at the same time!
![]() What about the sound as I turned the engine by hand? Is that normal?
Sounds like you may have something in your bellhousing that's getting into the flywheel. By the way, it's very hard to roll start a car in reverse and also not such a good thing to do anyway since reverse is not a well supported gear in the tranny.
Have you tried to roll start the car in one of the forward gears like second?
1972 Porsche 914 Project 2000 BMW M5 1973 Aermacchi 350 |
No, I haven't been able to. Our driveway is fairly steep, and in order to bump start in 1st or 2nd gear, I'd have to roll it out to the street, which means, if it didn't start, I'll need help pushing it back into the garage. I don't think my pregnant wife would really appreciate me asking her for help with that
![]() Once I get someone over to help, I'll try that.
Slumlord
Based on what I've read:
In neutral the engine turns over easily. So the the engine is not 'locked', the tranny is not locked, and the clutch operation should not be an issue at this point. I would do a few things: (in this order) Put a jumper from the starter body to the -ve terminal on your batter. Unlikely to help, but easy to do. Check the battery voltage while the starter operates, or just put jumper cables on your car, your new battery may be bad. Pull the starter and make sure it works on the bench. If the starter works on the bench verify that 12V is getting to the starter and the solenoid (when the key turns). i.e. verify the starter is wired properly. Use a pry bar to gently turn the ring gear when the starter is out. Make sure this is possible to do. Based on what you've posted the ring gear should turn easily. Don't move it too far, just make sure it's free. You do not want to run the cams backwards. |
That graunching sounds like the ring gear hitting something. Does it make the same noise if you remove the starter and turn the fan pulley?
Edit: can the ring gear be installed incorrectly and the starter is not engaging the teeth beccause of it?
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
Ok, sometimes we have to make stupid mistakes to keep us humble, right? The big black lead from the battery wasn't #$&%ing attached!!!! I have NO idea how I missed that, but after I pulled the wires on the starter, the easy lower nut, and was searching for the hidden upper nut to remove it, I noticed this big black wire. I thought to myself, hmm, did I just pull that off the starter? No, I don't think so... Better hook it back and and try to start it to be sure, before I yank the starter. Turned over on the first try. So I'm not sure if I'm deliriously happy or frustrated.
But I didn't let it fire, because there was some noise coming from the tranny. Is it possible it's sort of "half" in a gear?
It makes the sound when I turn the engine by hand with the tranny in neutral.
When I installed the ring gear (you mean the large ring that goes around the flywheel with the teeth for the starter motor to engage, right?) I remember being very careful about it (it was about 3 weeks ago now) and it was obvious - it either would only go one way, or was symmetrical so it didn't matter, but I don't remember which now.
Slumlord
Some noise from the tranny is normal, even in neutral, the input shaft is still rotating if the clutch is not depressed.
Half in gear is unlikely, but 'about to engage' is possible. Fire it up chicken little. |
Hi Christien,
Just so you know - I'm rooting for you my friend. I unfortunately don't have any advice - since I have yet to get everything back togeather again. I'm doing pretty much the same thing as you - replacing the clutch and doing the tranny. If I think of anything or get where you are soon, I'll be sure to let you know. Semper Fi, Mike |
Can you 'feel' the noise? Either through the spanner as you turn it, or with one hand on the case as you turn it?
I think it must be too long a bolt somewhere rubbing on something (Like when I changed my inner CV's and the bolts were too long and have carved a groove into my tranny case grrr)
Ok, it'll definitely fire if I let it, but something's clearly not right. Have a listen to this recording I just made:
http://cledroit.googlepages.com/start.mp3
Come to think of it, I should move this back to my rebuild thread, because now we're back to tranny rebuild issues:
Christien's 915 rebuild
Thread Tools | |
Rate This Thread | |
