rib rib is offline
rib's Avatar
Got problem need a quick answer
Hi, I want to fit a pair off SSI Heat exchangers and found a pair with oil-lines with only 30 minutes on them for a good price.
In the description it says will fit 3.2. I have a 1985 3.2 911. I have already found out from mailing the guy they dont have O2 Sensor socket. His response, weld one on.
My question will these fit my 1985?
Part No. SSI 143 4182, SSI 148 4940.
I need to know ASAP.
Old 06-20-2008, 05:45 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Quick...Yes. With the welded bong.
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 06-20-2008, 05:57 AM
Friend of Warren
Yes they will fit. You can get the bung at most auto parts stores. Need to drill a hole and get it welded on, but that is not a big deal.
I see you are in Amsterdam. I thought the ROW 3.2 engines didn't use the O2 sensor, but I could be wrong.
Kurt V
Old 06-20-2008, 06:07 AM
rib rib is offline
rib's Avatar
So, what is the difference between the 1965-1983 SSIs and the 1984-1989?
Old 06-20-2008, 06:10 AM
rib rib is offline
rib's Avatar
just to let you know, that Euro 911s do have an O2 Sensor. Checked with Porsche Amsterdam. Nice guys.
Old 06-20-2008, 06:20 AM
Wavey's Avatar
Check this thread:
http://66.236.61.177/showthread.php?t=413973&highlight=SSI+diameter
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 06-20-2008, 06:35 AM
Some euro Carreras have one, most do not. Porsche offered it as an option. The original 930/20 engine fitted to Carreras does not have it.
JR
Old 06-20-2008, 07:48 AM
You can weld on the bong or get a SW chip that dose not require an O2.
Old 06-20-2008, 07:53 AM
rib rib is offline
rib's Avatar
I have got SW chip so, no need for the bung-Correct?
I understand the differences between the early SSI which, have a thinner Flange and none protruding Header tube and later from 1984-89 have a thicker flange and protruding tube. Apart from that I understand they are the same.
The early will fit the later but later will need modification-Phew!!! I need a beer
Old 06-20-2008, 08:32 AM
Slumlord
Porsche_monkey's Avatar
Lots of guys unplug the O2 sensor. You might not even need it.
Old 06-20-2008, 08:56 AM
Slumlord
Zef has bongs on his mind today. He meant bung.
Old 06-20-2008, 08:57 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Bung...Bung...Bung...
<IN GAS WE TRUST>
Old 06-20-2008, 09:15 AM
heat duct mods required.
206 637 4071
Old 06-20-2008, 09:28 AM
rib rib is offline
rib's Avatar
Thumbs up You are correct
JR
After speaking to Porsche Amsterdam and the UK, who said after I had given my chassis number that I did have a O2 Sensor. I then finally looking underneath my car-their is no O2 Sensor. So, Javadog you are Right!
Old 06-23-2008, 06:01 AM
Just to be sure, make sure you have a 930/20 engine. The engine number will be stamped in the right hand side of the case, to the right and towards the bottom of the cooling fan. It's a little hard to find, so grab a flashlight and start looking. If you have a 930/20, there was never an O2 sensor. If it is another engine type, you may have had a sensor and a previous owner may have removed it.
Only one way to know for sure.
JR
Old 06-23-2008, 06:17 AM
