Bill is Dead.
cashflyer's Avatar
Header outlet spacing question
This should be easy for somebody to answer, but I couldn't easily find a clear answer when searching.
My 78SC had SSIs and a custom fabricated muffler system that consisted of Bursch collector pipes and a Flowmaster muffler. The muffler system is now shot and must be replaced.
Are the outlets of SSI headers at the same width and position as stock exhaust - so that I just order a regular off-the-shelf muffler system for my car? The Bursch pipes I had look like the 75-77 set in their ad. (bottom right of the picture below)
Adding to the confusion, I see the M&K (pn MK-MNEB-21-T) says it is for 74-89. Is the outlet spacing the same for a 2.7, 3.0, and 3.2??
Old 06-06-2008, 05:24 AM
I am having a little difficulty sorting out your question. I am assuming that you are saying that your car still has the SSI heat exchangers and you need a muffler to fit them. If that's the case, you need a muffler that fits cars up to 1974, with two inlets.
The muffler that originally came on an SC had a single inlet on the left side, which will not work with SSI heat exchangers.
JR
Old 06-06-2008, 05:56 AM
Crotchety Old Bastard
RarlyL8's Avatar
SSI are early 911 stock replacement heat exchangers. Any dual inlet muffler built for stock early heat exchangers (pre-1974) 911 will work. All are the same distance, 2.0L - 3.2L.
Old 06-06-2008, 06:02 AM
Bill is Dead.
cashflyer's Avatar
That was exactly the info I need!!
Thanks to both of you!!
Old 06-06-2008, 08:05 AM
