WUNDERWAFFE
JINKATIN's Avatar
My first engine drop
I'm starting my first engine drop on my 86 Carrera. I'm a bit nervous but I think I will survive. I'm fixing a few oil leaks, clutch job and a clean up. Wish me luck guys, I think I'm going to need it.
Charlie
1986 Carrera
Old 12-18-2012, 05:38 PM
83 Targa
I am right on your heals Jink. I need a clutch and some rear struts. I also plan fix a couple of leaks too. I just finished helping a friend drop a 912 engine tonight and we had the clutch exposed shortly after the drop. I just had to see how involved the clutch was. Don't be nervous. Check out the while you're in there list too.....what a great site and such good help as well!
Old 12-18-2012, 05:57 PM
CorsePerVita's Avatar
It honestly is not all that bad. I would much rather drop the engine on any 911 any day of the week than any other car.
The pelican article is quite helpful
Pelican Technical Article: 911 Engine Removal Made Easy
In fact, one the engine is out everything is very accessible and all right there. Once a person gets good at it you can have the engine and transmission on the floor in about an hour (or less for the quick guys).
My very first time doing a drop on my 911 included clutch, ignition bits, tuneup, vacuum hoses, sensors, etc etc... I had it all back together in about a weekend (taking breaks of course, not all in one setting).
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS
Old 12-18-2012, 06:02 PM
Word of advise..........
Charlie,
Do not rush things and be safe. Take it slowly and would be prudent to have someone around when you drop the engine. I don't know what your set-up, hydraulic lift, floor jack, engine dolly, etc. Make a list of things that have to be done and review that list before doing the drop. I don't use a list anymore after more 20 years of doing this work but my first G-50/engine drop 2 months ago showed the need for it. I missed to disconnect/label two (2) vacuum lines from behind the engine.
Take as many pictures you could get for reference. Use zip lock bags and label them accordingly. In case of doubt, stop what your are doing and ask. Keep us posted.
Tony
Old 12-18-2012, 06:04 PM
WUNDERWAFFE
JINKATIN's Avatar
Thanks fellas, appreciate the vote of confidence. Definitely taking it slow, don't want f anything up, or myself up.
Charlie
1986 Carrera
Old 12-18-2012, 06:37 PM
Here's my checklist for my recent 1986 engine drop. I followed the Bentley manual with good success, except it is easier to disconnect the speedo sensor at the trans rather than in the tunnel and fish wires through.
I got the car up high and level, then dropped the nose once the engine was down to get the rear to lift. Even then I had to raise the rear another 2" to get the engine to clear as it was rolled out.
It really wasn't that hard. Some photos in case that helps.
Re and Re Engine and Transmission:
Disconnect Battery
Remove Bumper
Drain Oil
Disconnect – oil tank breather hoses (2), at tank
vacuum line and breather hose from emission control valve, at tank
air filter vent hose
Disconnect – heater hoses
coil wire
mass air flow power wire
engine harness connector near coil
ground wires at #1 intake runner
CHT sensor white
speed sensor black
reference sensor red
O2 sensor
Disconnect – fuel supply at top of filter 19mm
fuel return at rear LS fuel rail 17mm
power brake vacuum hose
Disconnect – engine harness at LR shock tower
ICV, throttle, idle, MAF connectors
Disconnect – shift coupler
Disconnect – accelerator pull rod ball joint on LS
clutch cable from lever and transmission boss 15mm
coil spring, circlip, small lever from shaft
press clutch lever forward, remove from spring and shaft
Disconnect – rubber S-hose
hard oil line to oil tank
Remove – sway bar 19mm + 12mm
inner CV joints from transmission 8mm
ground strap 13mm
starter motor power lead 13mm
speedometer sensor 10mm
Support engine and transmission
Remove – engine and transmission mount bolts 19mm
Lower Away! Slowwwwly, down and back.
Separate Engine and Transmission
Disconnect – accelerator rod
reverse light connections
other starter connections
Installation is the reverse
1986 3.2 to 3.4 conversion
Old 12-18-2012, 08:50 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Hey C A,
Call me if you need me!
J
'85 Carrera Targa
PCA/POC
Old 12-18-2012, 09:29 PM
WUNDERWAFFE
JINKATIN's Avatar
MNez, Nice car and thanks for the list.
Jim brother man, will give you a call bro.
Charlie
1986 Carrera
Old 12-18-2012, 10:00 PM
83 Targa
MNez....Impressive and looks like a set up for a one man operation. Nice!
Old 12-19-2012, 06:48 AM
Nice ride. These cars are really a pleasure to work on, as long as they have not been molested in the past; which does not seem to be the case with your car...
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html
Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things.
Old 12-19-2012, 07:44 AM
Good set-up for engine drop.........
If there is one thing I would change in the set-up is use a taller and bigger jack stands. Those jackstands were over extended (last notch) other than that, I like it.
Tony
Old 12-19-2012, 07:51 AM
Car dollies under the front wheels?
Really?
Scott
'78 SC mit Sportomatic - Sold
Old 12-19-2012, 08:08 AM
Guardsred911's Avatar
That does actually look a little scary now that you mention it...
J
911 SC - 1980
911 S - 1977
Old 12-19-2012, 08:18 AM
Sorry guys, the front was stting on the ground for the drop, put the front dollies under prior to putting on the back wheels and lowering the rear onto dollies. Half way through it occured to me to take a picture. It's on dollies so I can move it back to its winter corner.
Stands were on the second last notch. It really was solid. And I had a second adult for the actual drop.
Old 12-19-2012, 08:31 AM
vash's Avatar
my first time i got a cheap grease board and a fistfull of dry erase markers. every time i disconnected something, i jotted it down.
it did two things..the obvious was it helped me put it all back..the second; it slowed me down. which allowed me to think things thru.
good luck.
poof! gone
Old 12-19-2012, 08:37 AM
Laneco's Avatar
Really?
Actually, I pull the engine the same way. The dollies help keep the valence from hitting the ground because of the lift angle and gives a few more inches of height. Also use a motorcycle jack on mine. Great tool.
My dollies are rated at over 2,000 pounds EACH so they are strong and safe. They do have a locking feature and depending on what I'm doing, I engage the lock. They never tip over and it makes it easy to move the car a few inches to re-position the jackstands at the rear.
Makes it so easy a girl can do it.
angela
Hello
Old 12-19-2012, 12:20 PM
WUNDERWAFFE
JINKATIN's Avatar
Finally, Engine down and out with the help of good ol' Jim Chang. Thanks brother, and thanks to
all
Charlie
1986 Carrera
Old 12-25-2012, 03:46 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Congratulation Charlie... Fix That For You
Who Will Live... Will See
Old 12-25-2012, 04:09 PM
