Which tool to remove these connectors
Have all these tools but which one will do it? Or is there another?
Trying to remove spade connectors from a mirror control switch harness. 1985 911 they still wont tilt! ![]()
Nothing special.
Use a very small flat head screwdriver to depress the tang and pull out the connector. The "tang" is on the other side of the spade connector your picture is showing.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
The back side of spade connector should have a small tab that you need to press while pulling the wire.
Use a tiny flat blade screwdriver or one of these connector removal tool kits found everywhere (amazon, bay, aliexpress, etc.) |
think I tried them all!
I have sooo many and I couldnt get them out.
Eye glasses screwdriver set, tiny little one.
Like all said, small flat screw driver.
Sometimes the tab is stuck to the connector, you have to push it from the back and then insert the screwdriver to flatten the tab and then pull. |
got it!!
now I have to figure which wires connect from switch to harness to mirror...different colored wires coming from harness from what is going to mirrors!
nightmare!!! tired of changing burnt fuses and diodes from inside the mirrors. Quote:
| Tags |
| mirror , mirror connector , mirror harness |
