Tom '74 911's Avatar
CIS Injectors test results
Hi -
I had my CIS injectors tested by WitchHunter this spring, as my engine was out and getting some other new parts - so I thought I'd treat it to that process "while I was in there". The report is below. They commented that injector #2 had a weak spring and should be replaced - it did have a lower crack pressure than the others as well as a higher flow rate.
So my questions are - how much worse, in the real world, is the #2 injector and what are the chances of finding a single replacement that will fit it w/my current ones specs? Is that cylinder just getting more fuel and running rich as a result? Is that bad?
Thanks,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 06-11-2008, 07:52 AM
Forgot the attachment:
Old 06-11-2008, 07:54 AM
LakeCleElum's Avatar
Since it's graded as "Good" and "Pass", I'd run it for now and start keeping your eye open for a replacement. For my 73.5, I found 5 brand new injectors on the Pelican swap site for $95.
You will know when it goes bad, the car will run poorly.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 06-11-2008, 09:09 AM
Tom,
Brand new CIS injector for your engine, '77 2.7 CIS, is listed in Pelican for $41.50.
Why wait?
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 06-11-2008, 09:57 AM
SC-targa's Avatar
That one injector is 30% rich at full flow. I'd replace it and have a smoother running, more powerful and more economical 911.
Regards,
Jerry
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 06-11-2008, 10:05 AM
