notfarnow's Avatar
'86 Carrera: Mystery wires
I was working on my father's 86 Carrera last weekend... changed the 02 sensor and head temperature sensor.
While I was working away, I came across these two "mystery" wires. They come out of a wire bundle that passes from the firewall to the rear fuse panel, on the left side of the engine compartment.
As you can see, these two wires come out of the "bundle" at the same place that a few brown ground wires come out.
Anyone know where these are supposed to go? I couldn't find anything obvious, and as far as I know, all the emission controls are present & accounted for.
Thanks!
'03 Carrera 4s
+ a whole bunch of boats
Old 06-10-2008, 07:01 PM
notfarnow's Avatar
In the Bentley, wiring diagram 970-27
5 "boxes" down it shows "NTC II" getting a red/black from the DME
What is the "NTC II", and could these be the wires that are supposed to go to it?
'03 Carrera 4s
Old 06-10-2008, 07:26 PM
the the is offline
An NTC sensor is a "negative temperature coefficient" sensor. I.e., a temp sensor were as temp goes up, resistance goes down. It tells the ECU what the engine temp is, so the ECU can make adjustments accordingly (richen when cold, etc.) I forget what NTC II is on a Carrera, but I think it's cylinder head temp.
That's not what those wires are. Your car would run terribly (if at all) with the sensor not connected.
Old 06-10-2008, 07:38 PM
wires
I have a 81 3.0 which i'm sure is not quite the same as the 85...but on mine same kinda mystery...and i was told they were for testing purposes you could plug some type of meter or gauge in to them... (shrug ) !!!! FM
Old 06-10-2008, 09:06 PM
WI wide body's Avatar
Jake, I've got an '86 Euro version Carrera and I just looked at my engine compartment on the driver side and didn't see those wires. However, I do have a large blue wire that I can't identify! I think it might have been an audio hookup in another time of my car's life. Let me know when you get an answer on those two wires. Looks like a brown/white and red.
BTW, I also just replaced the O2 and the HTS. My biggest problem was getting the damn rubber grommets in place around the Head Temp Sensor plug wire and the other two wires that go thru the grommet. Vaseline solved it!
Old 06-10-2008, 09:40 PM
jeff1hughes's Avatar
I am almost positive those are for the rear wiper. I did a similar quest for this info a few years back. My '86 has the same loose wires too, and no wiper to hook them up to.
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 06-18-2008, 08:01 AM
I seem to recall seeing the same thing on my '88. I'll look again.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 06-18-2008, 08:24 AM
Monkey Butt Forespin
84_Carrera's Avatar
3rd brake light?
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 06-18-2008, 09:16 AM
Red and brown... power and ground. Rear wiper or rear euro fog light? (though I think the fog wiring is usually back by the rear fuse panel?)
Old 06-18-2008, 10:32 AM
KTL KTL is offline
Schleprock
KTL's Avatar
They're not connected to anything on my car either. Never have been since I first bought it, before I started taking everything off the car........
Kevin L
'86 Carrera "Larry"
Old 06-18-2008, 11:16 AM
Friend of Warren
Rear wiper.
Kurt V
Old 06-18-2008, 12:08 PM
