3.6 conversion install troubles
I am in the middle of installing a 964 3.6 into my 77 and I am having 2 issues:
1. got fuel, got power, no spark. everything seems to be wired up correctly but no spark. 2. see the attache picture any idea where the black hose goes that i am holding in the picture? it does not seem to have anywhere to go. ![]() any ideas would be appreciated!! I am excited to hear this engine come to life.
Jim R Gruppe Member once upon a time when you could run generators in Cambria to fix the cars and hit 150+ mph on the fun run "Alles ist gut" 2011 997 GTS "Orange Pepper Wagon" 2009 Cayenne GTS |
hose
![]() Is that it (second down)? That pic is taken top (drivers) side of the motor (Varioram)
James 91 Black on Balck 964 C4 (DD) 82 Metallic Red SC 3.6 Varioram (sold) |
couple quick things to check
the wire from the dme to the fuse box connecting the two harness together in the motor depart ment make sure you have repinned it right did you check to make sure the crank sensors is right on the fly wheel o and you have to ground the dme, Kevin |
There is also the chance that the 2 sensors plugged in at the bracket on the foreward drivers side are interchanged. One is to the cyl head temp sensor and I think the other is the crank position sensor. I know they can be reversed because I did it when installing my 3.6 several years ago It then won,t start.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
I think the hose is for the power brake booster. I don,t think a 77 has boosted brakes. Cap it better than with tape or the resultant vac. leak will also make it hard to start.
thanks guys, the hose is not the power brake booster. that is already hooked up and yes the 77 has power brakes. this hose comes of of the center of the intake under the throttle. any other ideas? for now i am going to plug it and see what happens.
as for the wiring, i know i have good ground but i am going to trace back all the wiring this weekend and see if anything else is incorrect. i hope to get this the engine fired up!!!
