polizei's Avatar
Twin plug install question
Hello,
I'm installing a 964 distributor on my car, and I'm getting ready to install the Andial splitter. The instructions indicate that I need to run a set of 14 gauge wires from the splitter to the coils in the engine compartment. Does anyone who has done this have a suggestion of where/how to route the wires? Any pictures are always a plus Thanks guys!
Andy
Andy - 1987 911 Carrera Coupe
Old 07-03-2008, 02:00 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
I installed the splitter under the driver seat then ran the wires under the rear carpet, out through the big hole for the wiring harness then up to the coils. It was pretty straight forward. You may be installing the splitter somewhere else. I have a photo of the engine with distributor but not the coils.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 07-03-2008, 03:26 PM
I did the exact same thing as Porsche84. There is a rubber grommet just under the carpet where is meets the floor mat. Just follow the dme cable back.
Old 07-03-2008, 06:28 PM
polizei's Avatar
Thanks for your help there guys. I got that straightened out.
I've run into another question, which I'm sure is elementary to most. The Andial instructions indicate that two wires need to be cut in half and then connected to the splitter unit: the green #4 wire (no problem finding this) and black positive lead from the fuse box. I'm having difficulty identifying the black positive lead as there are multiple black wires in the harness. Is this referring to the smaller fuse box in the engine compartment? I've taken some pictures of where I think I should be looking, and I am hoping one of you kind souls would direct me specifically.
DME harness:
"Fuse box" in engine compartment:
Back of "fuse box":
Thanks for any help you can provide!
Old 07-19-2008, 05:21 AM
abit off center
cgarr's Avatar
I did this almost 3 years ago, as I remember they are looking for a positive black wire which is hot with the key? You may have to check a few with your meter to see which one is only hot with the key.
______________________
Craig
G2Performance
Old 07-19-2008, 06:35 AM
cdrik915's Avatar
What is the "Andial spliter" please ?
I see you install the 964 distributor : is it for set up your engine to twin ignition ?
Thanks !
Cedric
LIGHTER = FASTER !!!
Old 07-19-2008, 11:00 AM
Porsche84's Avatar
Here is a picture of a splitter. I've learned a bunch since I bought mine. I think you could accomplish what they've done for a lot less using off the shelf Bosch exciters.
Jerry Austin
Old 07-19-2008, 03:37 PM
polizei's Avatar
Thanks !
Cedric
Yes. You must have some means to split the signal from the Carrera DME to run the lower plugs. The Andial splitter is a popular solution.
Old 07-19-2008, 07:06 PM
Jerry,
Please elaborate!
I like cheep thrills. How would this be done?
QUOTE=Porsche84;4070867]Here is a picture of a splitter. I've learned a bunch since I bought mine. I think you could accomplish what they've done for a lot less using off the shelf Bosch exciters.
[/QUOTE]
Old 07-19-2008, 09:10 PM
polizei's Avatar
Thanks for the info guys.
Another quick question. The 964 distributor has a small black plastic housing which looks like it should accept some wire. I don't have any such housing on my Carrera distributor. What gets plugged in here?
Old 07-25-2008, 08:55 AM
abit off center
cgarr's Avatar
Nothing gets plugged in there. You can remove the pickup inside if you want.
Craig
G2Performance
Old 07-25-2008, 09:00 AM
polizei's Avatar
Did some thing get plugged into it in the 964/993?
Old 07-25-2008, 09:04 AM
Max Sluiter
Flieger's Avatar
Do you have the O3 vent modification for your 964 distributor to extend the life of the belt linking the 2 rotors?
Old 07-25-2008, 06:00 PM
polizei's Avatar
Yep, I've got the vent kit. Thanks!
Old 07-26-2008, 07:05 AM
polizei's Avatar
It appears that the lower plug holes are too small to fit a 13/16" socket. Is this normal? Is it ok to run different plugs in the lower than in the top? I think I would need a plug with a 14mm thread and fits a 5/8" socket.
Old 07-26-2008, 07:07 AM
abit off center
cgarr's Avatar
Did they machine your heads for 12 or 14mm plugs? If they did 12mm then thats what you use. When I machine heads I only do the 12mm second plug, it leaves more material in the head plus you do not have any clearance problems with the stock head nuts. There is no problem running smaller plugs in the second hole. I use the NGK DCPR6E spark plug which is a 12mm plug.
Craig
G2Performance
Old 07-26-2008, 07:35 AM
polizei's Avatar
Craig, the lowers are definitely 14mm, but I can't fit the 13/16" socket into the drilled hole. Do you know of a plug that would have a 14mm thread but fits a smaller socket? Or is there some trick to tightening it as is?
Old 07-26-2008, 08:14 AM
polizei's Avatar
abit off center
cgarr's Avatar
What size is the plug bore in the head? If its a 1" then I think you are going to have a problem, I dont know of a 14mm spark plug that uses a 5/8 socket. My 13/16 plug sockets are 1.050 OD I guess you could turn down a socket to just under an inch but it would be really thin.
Edit: I just looked at the picture of your heads, the holes look larger than 1" is the socket hitting on the cylinder head nut?
Craig
G2Performance
Old 07-26-2008, 08:37 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
This is a pickup (Hall sensor). On a 964/993 the DME needs to know the crank position with respect to 720 degrees for knock retard control. The flywheel sensor only "sees" 360 degrees.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 07-26-2008, 09:43 AM
