jonbot's Avatar
Higher than normal engine temps
I've owned my car for almost a year now, and up until a couple of weeks ago it never ran above the midway point on the oil temp gauge. It would normally sit a little below the half-way point, even during some semi-spirited driving.
A couple of weekends ago I went on a drive with a local Porsche club and was driving the car fairly hard, not probably as hard as I would at a track, but a little bit more than "spirited". During the run I noticed my oil temp creeping up a little past the half way mark, not in to the red, but getting up there, almost half way between the mid point and the red. I figured it was because of the spirited driving, and took it easy for the rest of the drive.
Since then, my engine temps are usually hanging out right at the half-way point, and more often than before, coming up just above the half way point. Any ideas what may have happened? This is my first air-cooled car, on a water cooled engine the first thing I'd suspect is the thermostat, should the same logic apply here?
- Everything's easier once you get started. -
'95 993 C2
'73 911 Targa
'88 BMW M3
'84 Mercedes 190e 2.3 16v
Old 07-09-2008, 09:33 AM
poorsha's Avatar
Next time you take it for a run check the front loop cooler.
It should be hot after temp is up to just below mid way.
If it is not it means your thermostat has quit or you have a kinked oil line from someone jacking the car and hitting one of the lines that runs along the passenger side.
If the loop cooler is hot that I strongly recommend you invest in the "cool collar".
This unbelievable device is unbelievable...honestly.
Did I mention I have one for sale
I do but they don't work.
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 07-09-2008, 10:18 AM
jonbot's Avatar
I don't know if "invest" is an accurate word... When I was out today I touched the tubing and it was hot, I'm not sure how hot it should be, but it was hot... If for some reason the thermostat was faulty, is it serviceable?
'95 993 C2
'73 911 Targa
'88 BMW M3
Old 07-09-2008, 07:47 PM
poorsha's Avatar
I don't think the thermostat is serviceable but it is replaceable.
If the front loop is hot then it is working.
Nice looking car.
What wheels are on it?
97 328i Convertible
Old 07-09-2008, 08:07 PM
OldTee's Avatar
Do some testing. Go to Harbor Freight or Sears and buy one of those infared thermoters and go hunting. Check various places to get an indicaton of what is running hot and where. Is your cooler working? Is your oil quanity proper.
Old Tee
all 911s sold
Old 07-09-2008, 08:15 PM
Is there anything in the motor compartment like the sound pad that may have come loose.
It is a long shot but sometimes something can be sucked into the cooling fan, sit on top of the cylinders and create a heat issue.
Is the car running the same. A lean (fuel pump, regulator) condition can make for a hotter motor.
A clogged cat could add back pressure and more heat.
Is it possible the fan belt might be slipping.
Again, a long shots.
Old 07-09-2008, 08:22 PM
Regis turd ab user
Is ambient air temp higher lately, how fresh is your oil and what weight is it, have you changed grades of fuel or spark plug heat ranges?
Old 07-09-2008, 08:53 PM
my hot side oil pipe runs around 190-ish maybe 200, and the cold side about 140-ish or so on a hot day.
You'd be surprised how much hotter the 911 will get on a warm day. Ambient temps above 90 make a huge difference. It got up to 105F today, and very humid. My oil temp at the temp sensor was about 210F. The cat got up to about 400F.
Old 07-09-2008, 08:58 PM
jonbot's Avatar
Yes, the ambient air temp today was hot, and also that day I went on the drive with the Porsche group. However, if I go driving in the evening, when the ambient temp drops, the oil temp is still high, it never used to do this. I'm going to do everything you guys suggest, check for loose sound pad, loose fan belt, check for kinks, and use infrared gun. I just don't want my baby running hot, I don't think it's good for her I'm thinking it may be good insurance to just spend the 50 bucks and replace the piston in the thermostat, just for good measure, what do you guys think?
'95 993 C2
'73 911 Targa
'88 BMW M3
Old 07-09-2008, 09:02 PM
I wouldn't touch the thermostat running to the front cooler. That can backfire big time. One thing you can do is adjust the contacts on the heater lever so that it turns on the heater blower while the heater flapper boxes are still open. This will blow cooling air through the heat exchangers.
Old 07-09-2008, 09:15 PM
jonbot's Avatar
Hah, that's not a bad idea I just got a new dayton blower motor, so maybe I'll try that.
When you mention the idea of replacing the thermostat "backfiring", are you referring to the process of taking the thermostat housing off of the car? Because I would plan on doing it while it's still on the car.
Oh yeah, to answer some of the other questions, I changed my oil 3000 miles ago with Brad Penn 20-50, do you think that could have anything to do with it? I always make sure my oil level is half way on the stick. I am running 91 octane, always have, and no, I haven't changed the temp of the plugs. My cat is gutted, so no clog there.
I'm thinking it may be a good idea to get the temp gauge with the numbers so I can more accurately keep my eye on things.
'95 993 C2
'73 911 Targa
'88 BMW M3
Old 07-09-2008, 09:49 PM
jonbot's Avatar
I just took a closer look at my temp gauge for those tiny numbers written on the side. According to those numbers, and if the gauge is linear, the half-way point between cold and hot is 220*F. The half way point between 220* and 303*(The beginning of red) is 260*. So apparently, my car was running at ~240*F That's not good, right? We have had some pretty high ambient temps of late, but something must not be working properly in the equation...
'95 993 C2
'73 911 Targa
'88 BMW M3
Old 07-09-2008, 10:34 PM
83 CHECKER
an oil change is due and in itself can dramatically lower your temp situation especially if you choose a synthetic, i was really surprised to see how my oil temp was lower totally across the board regardless of outside temp and humidity. best of luck, Bob 83 cab
Old 07-10-2008, 02:43 AM
83 CHECKER
Another quick note, others had me skeptical of going synthetic over dino, some stating it will cause more leaking issues etc. my mechanic talked me into it and i'm sure glad he did, in speaking with motorcycle owners they also tell me how it lowers their temps as well, i still get the dime size drip i always got no better no worse but it runs so much cooler.
Old 07-10-2008, 02:47 AM
How would that help cool the engine/oil? Cooling the exhaust? Don't see that really helping much if at all.
In fact, don't a lot of racers heat wrap the exhaust headers to keep them hotter so they will flow better? If so, it might be counterproductive.
Just asking the question.
Jonbot, air cooled will run hotter on a hot day, and hotter when you drive it harder (water cooled tend to stay more even temps - that's one reason P went to water cooled, too hard to control emissions w/ big temp fluctuations).
Old 07-10-2008, 07:52 AM
Has the mixture or timing been changed recently?
Old 07-10-2008, 11:33 AM
jonbot's Avatar
No it hasn't. However, ever since I purchased the car i've been having some off-idle surging. I've worked on the fuel system a little, I got some fuel pressure numbers, and tried paying with the CO adjustment, doesn't seem to help. When I posted the pressure numbers on here a couple months back, I believe it was paulporsche who mentioned that my numbers appeared to indicate that the car runs too rich when cold, and too lean when warm. I'm gonna tinker with the WUR today and see if I can get the pressures back within spec... I got the fire extinguisher ready, wish me luck!
'95 993 C2
'73 911 Targa
'88 BMW M3
Old 07-10-2008, 02:05 PM
I mentioned the external thermostat going to the front cooler. The thermostat body is threaded aluminum, and the threads are known to strip out and stay in the steel oil line nut while the nut is removed. I'd leave it alone unless you are going to change the lines, and even then there are tricks to it.
Racers have headers. If you still have factory heat, then you have heat exchangers, not headers. I don't know about wrapping them to make them hotter and flow better.
I don't have an SC, so I could be wrong on this, but don't some SC owners plug off the ignition advance vacuum in order to get the car to run cooler?
Old 07-10-2008, 02:19 PM
Born to Lose, Live to Win
ramonesfreak's Avatar
my car seems to be extremely sensitive to the ambient temperature and humidty. when we have a humid 80+ degree day, the temp runs at about the middle point. below 80, its usually in between the first two white lines. if its in the 90's, the temp will crawl past the middle point and then i take it easy on the motor and avoid stop-go traffic.
And when I said "sensitive"...what I mean is : if the engine temp is up a little high because its hot outside, even when I get on the highway and cruise in 5th gear at a conservative speed in order to cool it down, it doesnt cool down.
it appears to me, that the actual temperature of the air has more influence on the engine temperature than the flow of moving air over the motor and oil cooler. this is the opposite of my experience with air-cooled motors. i used to have a harley-davidson that if in traffic, would almost over heat. once cruising at a decent speed, the air passing over the motor and oil-cooler would cool the engine down immediately - not so with the 911, i think for obvious reasons
ive come to believe this is normal with my 911
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 07-11-2008, 09:21 AM
Scott,
That seems normal to me too. I keep my engine and oil cooler clean in the summer, and keep the oil topped up. Cleaner oil also helps to keep the engine running cooler.
Old 07-11-2008, 10:23 AM
