How do you get Fuchs polished when the anodizing has been "spun" off?
I had a really hard finish on one of my Fuchs wheels. To get the anodizing off I had a wheel repair shop sand blast it. Well they also spun the lip using some sort of abrasive and so now it is full of lines. How do I get it so that it is perfectly smooth again and therefore takes a great polish? Do I sand it?
Old 07-19-2008, 05:22 PM
depending on how deep the "lines" are, start with a reasonably fine sandpaper and work your way up until it's really smooth. Then start with the polishing compound. I think I went from 800 up to 1500 wet sanding mine before I polished them. It's a lot of work, but the smoother you get them before polishing the better the end result will be.
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 07-19-2008, 06:37 PM
Immature Member
dentist90's Avatar
Now that you have polished wheels (not anodized), you can (should) use Al/Mg polish and wax them afterwards to help keep them shiny longer. Unprotected alloy will oxidize fairly quickly.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 07-19-2008, 08:09 PM
I sanded the very outside outer 1/2" anodized lip (hard stuff to start with) starting with a small electric hand sander (60, 120, 200 grit as I recall), then followed up wet sanding (by hand) with a few more finer grits up to 2000. Then Mother's Aluminum & Mag polish and that technique got every single sand mark out and a perfect polish.
Old 07-20-2008, 04:33 AM
