Detached Member
Cat heat shield for A/C condensor, your thoughts
Sorry I didn't take a pic before installing it. But I made a heat shield out of two heavy duty throw away aluminum foil baking pans and an inch think of regular Owens-Corning spun fiberglass insulation. Sandwiched the insulation and used a desk stapler to staple the edges. Why did I do this? I have an A/C condensor in my left rear behind the wheel well. You can see the condensor and fan in the left side of the pic. The reason was 1) the condensor can "see" the cat, thus radiant heat, and 2) I stuck a thermometer in between the two at idle, hot and was getting about 120 degrees F. Thus I think the condensor was acting more like an evaporator. Any thoughts. The cat is open to the air on the opposite side of the heat shield. The cost was about two bucks.
Hugh Last edited by Hugh R; 07-13-2008 at 09:17 PM.. |
It would be interesting to get the "after" test data.
1989 Carrera 3.2L in 993 bodywork |
I bet that will help since the cat gets really hot. I just checked mine after a 20 minute ride and it was 450+ degrees F while everything on the engine was around 250.
'86 911 Sunroof Coupe '91 Miata '77 BMW R75/7 |
Make sure it's not touching the cat, should have an air gap.
Heat
Inferred heat is your enemy here. Aluminum does not radiate much in the inferred wavelength. As long as the cat does not destroy the aluminum you did good.
Neat idea! How did you mount your new "heat shield" to the existing cat shield?
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Detached Member
Good point about an air gap between it and the cat. I'll double check tonight. I loosened the metal shield underneath the cat and just stuffed it in there. It's stiff enough that it doesn't move on the top half unless I physically bend it.
Hugh |
Detached Member
I just finished driving the car about 10 miles and stuck my hand on the heat shield that I made. Honest to god, the surface temperature of it was just barely above ambient! I'm still going to put some high volume computer muffin fans on the front condensor by elongating the existing fan hole, removing the spare tire and double stacking two more sets of fans. I may re-evacuate and re-charge with R-134a. I may have introduced a leak when I pulled a vacuum last time.
Hugh |
Throw it on the ground!
http://www.spalusa.com/ ![]()
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Mark: What size fans are those? Is that a stock condenser in a non-turbo car? I assume they're "pullers," correct?
Nice installation...
1984 Targa |
Looks just like a stock condenser. Not turbo (Carrera, 84-89, looks like). Should be 'pullers'. If they're not, reverse the wires. |
Detached Member
I have a wing with three 4" computer fans. Maybe I'll try two of those big Spals.
Hugh |
All the details here: Adding 3 fans to rear A/C condenser
Thread Tools | |
Rate This Thread | |
