Goldfinger
I got new tires put on yesterday.......Front end was jacked up first and I was there to supervise. We put the car back down and the front end was about 1 1/2 inches higher than before. I figured that it would settle down after it rolled a bit but after 30 min. on the freeway it's still stuck up in the same position. My steering wheel is not perfectly straight as it was and it feels floaty on the road. What the hell???? Anyone ever have this happen to them?
1984-Carrera (pewter metallic) |
How did they jack it up? And from where?
Todd
'81 SC |
abit off center
Sometimes the torsion bar caps (adjusters) can come loose when you take the weight off them.. Jack it back up and make sure they settled back in place.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
"floatiness"could be the tires not yet breaking in, so to speak...I'd like to know the jacking points, too.
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Goldfinger
They jacked it up with 2 floor jacks. One on each side under the front controll arm pivots. I helped line up the jacks. It all looked good to me.
Goldfinger
Do they move around in there? Is the end of the adjuster bolt off to the side maybe or is there some kind of divit or cradle that the bolt is suppose to sit in?
The same thing happens every time I jack it up. But after a few hard braking nose dives it goes back to normal.
Scott 77 911s |
(the shotguns)
Mine has taken some time to settle after being in the air for quite a while.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Goldfinger
Just got back from the allingment shop and the adjuster seems to be in its right place......We jacked up the front and put some anti-sieze between the adjuster bolts and their stops. Same story; The thing is still sitting up and won't settle back to its original setting. WTF?????????????????????????????????????????????
You might try a few 'panic' stops with a full gas tank, see if that works...
Or have Tubby and Little Lotta sit in your trunk... |
Goldfinger
I've tried the pannic stops but not with a full tank of gas yet........That's next on my list.
abit off center
I have to ask, not being a smart a$$ but is the car really 1 1/2 inches higher if you measure the front bumper or wheel well or is there just a bigger gap between your fender and tire? and I assume the new tires are the same profile?? A picture would be nice because I cannot get that much adjustment out of mine without re-indexing the bars.
Goldfinger
The front bushings (if they are still stock rubber pieces) will eventually slip on the A-arm once it is rotated enough (somewhere around 25+- degrees on mine). The bushings probably provide 10% of the wheel rate in front, so a slipped bushing from jacking up the front end could cause your issue. A few good bumps with a full tank should re-slip it where it belongs.
You could always lower it a couple of turns via the adjusters, and when it ends up too low raise it back up. Seems odd that this would happen with the strut still attached - the rebound stop in the strut doesn't allow that much travel (I think around 4" of rebound from design). Or is your car dropped to the weeds (aka "euro height" or lower), which would give you 5-6" of rebound and 2-3" of jounce? I also have noted a 1/2" to 3/4" variation in front end height going from a full tank to almost empty.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Goldfinger
I just needed to update some facts about my front end........All is good. I got in a pinch and needed some tires for a weekend trip as mine were getting pretty thin and I was going to the coast with my wife. I didn't want to chance anything since I was going to the coast by way of Bear Camp Road. Any Oregon local will understand why I wouldn't want to take that road on nearly bald 12 year old tires. There was a shop in Medford that had tires that were the correct size and they could get them mounted before I had to leave the next day. Never heard of the tire but they were cheap. Anyone ever heard of Nexen tires? I never want to hear of them again. On the drive home my Porsche felt like a wrecked VW bug.
After putting 500 miles on the tires and going to the alignment shop to get the front end checked out; I realized it was probably the cheap tires that were the cause of the problem. The ride hight issue was just from a different OD on the new tires. The company I got the tires from were very good about taking back the tires I got from them and I'm now rolling on Michelin Pilot sports. They ordered them and had them in 3 days. An extra $380 and everthing is glorious.
All due to OD differences?...what were the sizes used?
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Goldfinger
The Handling problems weren't due to the OD..............The ride hight in question was due to the OD. The problems in handling was directly related to the cheap tires I had put on. The size of the tires were the same as the new Michelin pilots I put on. Stock. 16" 205 55's in the front....225 50's in the back. I think there can be some differences in actual size between manufacturers even though they have the same sizing printed on the tire.
912 Geek
As my high-school science teacher used to say, "This is true." You'd be amazed at the difference in actual vs. stated sizes between different tires and brands. Where's the Bureau of Standards when we really need them? Frank |
Goldfinger
No Doubt.......
