You have a different housing, mine is external. Check the site and diagrams once you find the corrsponding bulb. I measured mine to make sure it would fit. I am not sure if the LEDs need to face outwards, but I am sure it would help.
Anthony Vanderlinden ---------------------------- 1987 Porsche 911 1979 BMW 635Csi Euro 1926 FN 1300 |
If you want I can measure the amount of light coming out of it if mounted sideways, so that the LED does not face outwards... I think that it diffuses light enough that it may not matter. Just let me know.
Don't think switching to LED's will help much. Little brighter, but still low to the ground.
Third brake light, high in rear window might help. |
I use not only LED taillights in a fiberglass RSR configuration and the stock CHMSL for cars later than mine ('83 SC) but most important a pair of motorcycle LED brakelight units--total of eight bulbs, four in each--that are mounted under the center bottom side of the tail. They are totally self-contained, no wiring, being powered by wafer batteries of the kind you find in some cameras. They are activated by the movement of a dollop of mercury inside each unit, and they can be adjusted (via mounting angle) to come on literally nanosecond-instantly when you brake--far faster than any conventional switch could react--and they flash in a jittering, back-and-forth pulsation. Superbright from directly behind (which is all I care about) and the batteries seem to last somewhere between six months and a year. I mount them with small pieces of industrial-strength Velcro, so I can remove them whenever I have the hatch open for awhile to do engine work.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Crotchety Old Bastard
Where can I purchase those?
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
I don't remember where I got mine, though I can search for the receipt if it's the only way for you to find 'em--lemme know (stephwilkinson@verizon.net). I learned about them from a PP thread about a year ago, so I'd start by doing a search for that. If you do a Google search for "motorcycle LED brake lights," you come up with a substantial number of hits, most fo them companies that supply wired-in lights.
Banned but not out, yet..
I went with Halogen tail/brake lights - a VERY noticeable difference with no ill effects to the wiring. Didn't see them from our host, but perhaps Automotion/Performance.
An air cooled refrigerator. ‘Mein Teil’ |
The problem with those halogen bulbs, I'm told, is that they get extremely hot and eventually melt your lenses. But I have zero experience with them.
They are NOT OK for taillights. They get hot enough that they will melt your lenses and damage the reflectors. |
I would like to know where you get your 'facts'? Can't be from first hand experience.
Probably not very strong (high-wattage) halogens?
