Wach, installed pic.
PhD on Pending Projects
Ooooooohhhh man!!! After seeing that photo I need a few minutes alone... Thank you!!
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
They were a variation on one of 9M's grinds, using max lift and duration compatible w/ stock piston tops. Don't remember the specs off the top of my head, but they were as lumpier than RS but not quite to RSR
They are almost the only ones in this country that can. The beauty of aftermarket is the ability for any one to tweek the maps based on what they are seeing in their car on a given day.
Bill,
A race built ECU would be great. My understanding is with the Protitech conversion you get the software to burn your own chips. My thinking is: It would just be cool to keep the stock Motornics. The stock Motronics are proven and reliable. There would be a savings of time and effort from not having to tare the car up for a rewire and to install a crank position sensor. This would will be an expensive conversion no mater. I believe $2600 for the PMO kit, $2200 for the Protimotive conversion, and maybe $500 net from selling off the stock 3.2 manifold. It could make for borader market appeal if PMO would got together with Todd or somone and developed a proven turn key packabe that keeps the Motornics and is easy to install in a day. This could be for the 3.2 or 964. Make it CARB legal and you could have a winner. |
Thank you all for your posts and PMs. Special thanks to Richard Clewett for his detailed email.
For my stock 3.0: Approximate cost of the basic single plug throttle body system(ECU, coils, PMO Throttles, injectors, un-terminated wire harness, fuel regulator, sensors & connectors, etc.), crank trigger adapter, cam sync adapter and spark plug wires is $6500. Stock CIS fuel pump will work fine for this setup... Now I have a $# that I can work with. Thank you again!
http://www.clewett.com/products/engnmgmt/emsys.htm
The simple things you see are all complicated; I look pretty young but I'm just backdated |
Insert Tag Line HERE.....
Almost stock 3.0SC engine with PMO
Hi folk's.
The thread is a few years old now, but here's my build. 1982 3.0 204hp ROW engine, CR. 9.8:1 with the following changed parts. 964 cams timed at 1.55 180hp heads with 38mm ports Complete Pre -74 Dansk exhaust Electromotive TecGT engine management PMO 46mm throttle bodies It now puts out 215bhp and 256Nm at the wheels. Corrected for 15% drive-train loss the engine is now good for 253bhp and 301Nm at the crank. ![]() I am VERY happy with how it peforms, it just pulls like a train all the way from 2000rpm until the redline ![]() Regards Eskild from Norway. |
How it looks
Here's how it looks in the enginebay
Turbo Hooligan
D-Zug ![]() |
Turbo Hooligan
D-Zug ![]() |
Childhood dream car: Porsche 959 |
Almost Banned Once
This has been on my "todo" list for about eight years... That happens when you're a single parent.
So my kids are grown and I'm redoing my "todo" list right now ![]() Thanks for the inspirational thread. Good luck.
- Peter |
1984-911 M491
Old School
1984-911 TLC......SOLD |
Not the PMO setup, but a little old school and new ideas that we did in a 73 car @ Rothsport.
Banned
Rothsport system, it is the best one out there,period.,btdt, Stef.
Sub'ed
1976 911/S/SC/BASTARD Mid9 Member #12 |
Is there enough clearance to clean air filter with out removing engine?
2010 Carrera S GONE 2022 Cayman T 2007 GT3 1988 Carrera |
Yes, no problem.
