Carrara oil cooler
Just got a used carrara oil cooler. It came with the hoses cut and now I need to disconnect.
I have read the fittings are delicate and I don't want to ruin the threads. Any suggestions on how to proceed?
Old 05-09-2016, 03:18 PM
That Guy
Techno Duck's Avatar
The fittings are probably going to be seized. I opted to slit the nut using a cutoff wheel on a Dremel. See this thread for details..
Replacing fender mounted oil cooler lines pictorial
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 05-09-2016, 03:24 PM
Send a message via AIM to fintstone
I cant imagine needing to cut the hose ends off the cooler. Don't risk damaging the cooler. If they don't come off easily, use some heat.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 05-09-2016, 04:31 PM
I second the heat. Mine took some heat cycling and 3 days of penetrating lubricant soak prior to reluctantly releasing.
1980 911 SC - Black on Red
Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html
Old 05-09-2016, 05:29 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Connectors.
"Blaster" is your best friend...........
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-09-2016, 06:05 PM
patz's Avatar
Penetrating oil, a large vise grip, channel locks and a gentle touch. "Lefty Loosey".
Old 05-09-2016, 06:46 PM
Nice looking coupe - '76?
If you're uncertain about the condition of the cooler, I recommend sending it to someone like Pacific Oil Cooler for a professional cleaning and inspection. To me, the cost of an expert cleaning is well worth the peace of mind in knowing there aren't some fine metal shavings in there that you're going to dump into your motor.
Old 05-09-2016, 08:22 PM
Probably not a huge concern as all the oil returning from the cooler will go thru the oil filter before returning to the engine. The filter will catch any debris before "dumping" it
into the motor.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-09-2016, 09:07 PM
into the motor.
No radiator cooler in this diagram, but the oil from the trombone cooler has to return to the oil tank thru the filter, just like the Carrera cooler.
Old 05-09-2016, 09:24 PM
