993 head studs
does anyone know if the 993 head stud has a coeficient of expansion similar to aluminum(like the dilivars?) and if they would work in a 2.7 motor? TIA Paul.
993 head studs are supposed to be the cure for that dilavar stuff.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
as yelcab1, yes, the fully threaded 993 suds can be used on all 911/964/993 and is a very reasonably priced quality part. For a little more the 993tt/RS studs are a little better.
Author of "101 Projects"
Yup, what Bill said. You can use the 993 ones. You can also use the original steel ones - they work very well, and are nearly impossible to break. Porsche was trying to apparently solve a problem that didn't really exist when they used Dilavar on the shanked studs. The 993 ones are not shanked, and are not made of steel, but made of a Dilavar, or Dilavar-like material...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
As Wayne mentioned above, the 993's are good items.
from my own research I found that the 993TT's were a excellent part, and that some have had issues with the ARP pieces. I personally have never had a issue on other applications using ARP parts. But I heard that the 993TT pieces good. I cant vouch for the RS, as I am not 100% on the difference between the two pieces alloy or design wise. Best of luck~
Taze em..TAZE EM ALL!! A man that builds a thousend bridges is a bridge builder, but a man that sucks one ( blank ) is a ( blank ) sucker. It looks like the 4th of July from my rear view, how about from your view? |
Irrationally exuberant
You don't want to be using steel studs on one of those. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Dilavar is a non-magnetic steel alloy with the same approx. coefficient of expansion as aluminum.
Dilavar Ni13 contains 13% Nickel, 5-6% manganese, 3-4% chromium + other alloys. As spec'd by Porsche, ultimate tensile strength is 180 ksi. * Expansion coefficient, Dilavar, 11.3 Al alloy, 10.7-13 Mag, 14 Mild steel, 6.33 Grade 4 Ti (6Al-4V), 4.6 AFAIK, the 993 fully-threaded heads studs are also Dilavar, but so far, this version don't have a history of breaking. Sherwood * Metals, Fibers and Materials, F. Aird, 1994 |
