Carrera Cab Connoisseur
nyne11's Avatar
Wiper arm reverse question
Being from Aus and having RHD my wiper arms are already reversed from most of your points of view, however I want to reverse mine to the passenger side (your drivers side). Question is for those of you who have done it is it just the reverse of what is in Wayne's 101 book or not? Also one arm is bent and one is straight. Do I reverse those as well?
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 08-14-2008, 06:39 PM
You have to pull the wiper motor assembly and reposition the actuator arm 180 degrees.
Old 08-14-2008, 07:29 PM
The wiper arm assy. can remain. Remove, then reverse the actuator arm. Then reverse the arm positions so they're a mirror image of the before photo. As I recall, the required bend in my arm was not in that orientation, but try it first and observe the glass contact pattern (with wet glass).
Caution: Don't operate the wipers with the trunk lid in the open position. Possible collision and paint damage.
Sherwood
Old 08-14-2008, 11:41 PM
Richard Burns's Avatar
Dave the wiper arm that is now in front of you is bent so that it does not come in to your line of sight.You need an arm that is bent the other way so that in the parked position it lays out of the line of sight of the passenger.ie: from inside the car now the drivers side wiper is bent down if you just change the wiper blades that you have now the bend will be in exactly the wrong place it will not sit down parralell to the bottom of the windscreen. You need to get a wiper blade from one of the american imports I would try Aporsha part in Melbourne for the correct blade for your purpose.
Regards,
Richard.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip!
Old 08-15-2008, 12:49 AM
nyne11's Avatar
Regards,
Richard.
Thanks Richard, I had a sneaking suspicion I would need a different arm. Other than that no problems?
Dave
Old 08-16-2008, 02:08 AM
FWIW, I bent the factory arm in a vise (w/cushion jaws) to the correct angle.
What's the "other vehicle" wiper arm that's suggested as a direct replacement?
Sherwood
Old 08-16-2008, 11:48 AM
The wiper arm is eminently bendable. You don't need a new one.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 08-16-2008, 01:38 PM
Sherwood,
The replacement arm that I refered to is the drivers side arm from any U S car. For you guys in the states it would be the drivers side arm off any right hand drive Porsche 911.
Dave, As we would say here in OZ to do the change is a piece of p**s.
Richard.
Old 08-16-2008, 10:59 PM
spence88mph's Avatar
I don't understand why you're doing this Dave!
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 08-16-2008, 11:52 PM
