Send a message via MSN to P Moore Send a message via Skype™ to P Moore
Dash Install
HI,
Im rebuilding my 1975 Targa at the moment and im wondering if there is anyway that the dash can go in AFTER the front window as im waiting on my Dash to come back,
As for the Rear Targa Glass / Rubber, What a pain of a job......im getting no - where !! !! one thing is gettiing the rubber on all the way around and then try keep it there and insert the chrome trim... i have read lots but never thought it would be this difficult...
Old 08-17-2008, 02:16 PM
19 years and 17k posts...
azasadny's Avatar
My understanding is that it's "impossible" to install the dash after the windscreen (windshield) is installed. We have a local glass shop that replaced my front windshield and they also confirmed this. They said they really hate to replace the rear Targa glass, so I figure if professional glass installers hate to do it, I'm not even going to try.... Good luck, you're a brave man!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 08-17-2008, 02:56 PM
efhughes3's Avatar
Targa rear windows are probably the hardest window to install in the automotive world. Period.
Good luck, but I'm under the impression the trim goes in before you pull the rubber thru to the inside with a cord. I don't think it is possible to push the trim in after the fact. I've been wrong before, however.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 08-17-2008, 02:59 PM
drm05's Avatar
While Targa rear windows are a good bit of work they can be done with a little background reading and prep work.. There are a lot of good articles on this forum that can be of great help..
Quick Targa window install trick
You can see the orange tie-down strap which held light pressure on the window while I pulled the cord.
You need to install the seal, defrost wiring and insert chrome trim before installing the window. Mine took about 2 hours prep and 2 to complete the install.. but it did take 2 attempts.
Good luck...
finished product..
Dan
1972 911T Targa
Old 08-17-2008, 03:50 PM
efhughes3's Avatar
Every Targa is a bit different. The guy that did mine was recommended by every Porsche dealer in the DFW area, he'd been doing them for about 25 years. He said some went in with little fanfare in an hour or so, some (like mine) took him several tries over three hours.
Ed Hughes
2015 981 Cayman GTS
Old 08-17-2008, 07:02 PM
techweenie's Avatar
Just to confirm: the dash has a 'flap' that needs to be attached to the dash structure with sheet metal screws. That is the main reason the dash must be replaced with the windshield out. However, getting a 911 windshield in and out is trivial once you've done it a couple of times.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 08-17-2008, 08:26 PM
Thanks for all your comment guys, Would it be a better bet to install the trim when the glass in in place, just before the chord gets pulled ??? (rear targa glass)
I dissconnected the defroster wires in the engine bay so i have room to play with there !!
Old 08-18-2008, 04:09 PM
efhughes3's Avatar
You will never get the trim in after the glass is in place. You have to have the trim in the seal before seating the seal in the car.
Ed Hughes
2015 981 Cayman GTS
Old 08-18-2008, 07:27 PM
3.2 CAB's Avatar
YES, the dash needs to be installed BEFORE the windshield is installed.
That trim piece is a compression type fit, and once the glass is in the sealing gasket, it would be almost impossible to install the trim pieces later. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 08-18-2008, 11:06 PM
