Retired Member
I bought mine from Pelican. I used it alot checking torque settings at DE events. It packed it in last summer. The plastic part seperated from the socket. I think if I can find an epoxy that will bond the nylon section to the socket it will be fine.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
(the shotguns)
i just have scratches on my lug nuts.
oh the horror.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Try using a plastic grocery bag over your nuts to keep them protected while wrenching on them. My nuts still look great!
68 911L |
Anyone think to try lining a socket with liquid electrical tape?
Carrera 3.2 - "Faster, Stronger, Better" |
(the shotguns)
B D my nuts need to breathe!
One more thought if you're gong to do a lot track events you should really have a set of steel lug nuts, then you could use your regular steel socket.
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
I'm going to order one of the nylon lined sockets from Pelican! Hey Does anyone have this set from Griots? http://www.griotsgarage.com/product/tools/specialty+tools/protective+socket+set.do I think they are metal inside but have a protective plastic outside. Greg ___________ 75 US Carrera 03 Cab 2 69 Camaro Pace Car |
I don't mind spending the money on one if it works, but I don't have a bottomless pocket either.
1985 Carrera Targa in the fastest color......Black........Growing list of goodies now includes SW Chip, M&K premuffler, Sport muffler, DME update, etc. |
Almost Banned Once
Slumlord
I use a zip-loc bag. Slightly thicker than a grocery bag, but yes it works at full torque.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
I bought some new lug nuts and thought "what the hell" and bought the SIR aluminum one that Pelican sells (although I shamefully bought it from another vendor). It broke on the SECOND nut I torqued.
1988 Carrera Coupe |
Soft Socket
Went through the plastic soft sockets (many years ago) and after handing over a aluminum deep socket to a local tire shop (yes they tried to torque to 500 lbs - or at least that's what the socket looked like after they were through), they ruined a set of new lug nuts with it too. I went to a deep Impact 6 sided socket (the deep impact is black so it stands out and doesn't get used for any other use).
I run the nuts in with a low torque hand held cordless drill. Have always finished with hand torqued. With this last new set of aluminum lug nuts if there is any sheen on the edges they get a touch up from a black sharpie. Love the idea for the 1-2 mill baggy over the nuts, I'll be trying that. Thanks. |
{Sorry, I typed out a big scenario of an idea, then thought twice about posting. If it actually works, I may have a new idea to patent.}
