Designer King
A better look @ the wheels.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Schleprock
Everybody needs to remember that 1977 Paul's yellow 911 does not have SC/Carrera flares (the flares began in '78) and therefore the 16x7 wheels will fill-out the rear of the car MUCH more than a 78-89 911. That's why the recommendation of spacers or bolt-on adapters is mentioned for the flared 78-89 cars- because 16x7 up front creates a wider front track and the rears still have lots of room to move outboard because of the much larger SC/Carrera flares. Spacers (or wider 16x8, 16x9 wheels) help fill-out the wheel arches better.
Kevin L '86 Carrera "Larry" |
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
img]http://forums.pelicanparts.com/uploads14/100_01881227335442.jpg[/img] I have room, but the tire sticks out just enough to rub over bumps, and turns |
Sorry, photo didnt load...
![]() Will attempt to upload...77' 911S with 205X55/16. Stock suspension for the Colorado back country.... |
I have some spacers leftover from the previous owner that I will probably throw on, I think they are 8 or 10mm. I have been thinking of larger spacers but was avoiding restuds or lip rolling. How necessary running all 7s.?
------- Glenn 86 3.2 Blk/Tan Wong'd Whale Coupe, Dansk Pre, Monty |
Designer King
my1st911,
My tires are 205/50 so they are approx 3/4" narrower than yours. Your tires are also about 3/8" taller. That, coupled w/ the characteristics of the particular brand of tire, may be enough to cause the rub. Your ride height seems more than sufficient to me to allow for clearance, though. In fact, from the pic, it looks like the center of the arch is at least 1 1/2" above the tire. I'm wondering if there is another issure here, like worn shocks or worn rear suspension bushings, which are allowing the body to fall onto the tire under load. OregonCab, W/ 7s and the same sized tires all around I think the rear track may be SLIGHTLY smaller. Whether this is problematic, I think, may be down to driving habits and car usage. The LOOK would be greatly improved by using the spacers to fill out the arches. Most likely a wider rear track would allow less oversteer and/or improve turnin. Aircooled911 has what I felt was the max dia for 16x7s on mid years; namely 205/55. I wanted to go slightly smaller (50) so I could go lower w/o issues. Ossiblue, As I wrote, I think that is the case re flare sizes. If someone knows this is incorrect, please let us know so w get this right. Remember, what I did is what I feel is a good aesthetic approach, especially for the type and location of driving I'm doing. If you are tracking the car you may want to explore other options, such as wider rear wheels, larger rear tires, welding on wider flares, etc. As KTL points out, SCs and Carreras already have wider flares, and can accommodate 8s on the rear, although the original post by mnmasauto referred to 7s on an earlier car.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 11-24-2008 at 06:26 AM.. |
35mm Adapters on rear
PCA-Chicago Region-DE Tech Coordinator-Retired PCA-Chicago Region GingerMan DE Co-Chair-Retired 1987 Cab-under construction-Sold pending pickup 1986 911- Race/DE car-Sold |
