sizes and code for early 911 fuchs
I am looking for the details on the size and codes for the fuchs that would have been fitted to a 1972 911T . i have a set on the car but i'm not sure if the are the genuine items that would have been fitted in 1972
"Funding my obsession one nut at a time" |
Fuchs w h o r e
Post some pics.
will do , but codes on them are 91136102042
That part number is for an 8x15, which was never used on a 1972 T and won't fit anyway. They came with nothing larger than a 15x6. The version that they used was what we call the flat 5, as opposed to the deep 6 of the pre-'72 cars. Here's a photo of a very dusty example that is on a car I pulled from a 20 year-long hiberbation this summer.
JR
javadog is correct on the code, those are 8X15 wheels and unless your car has a high ride height or SC flares, they would be difficult to fit.
I believe the 6X15 code for a 72 has as the last two digits, 10 or even 00. Later flat 6's have a 40 at the end. You may wish to try and find the manufacture date on the back of the wheel--around the center hub--and that will narrow down if they are proper for the car. Regardless, 8X15's were not fitted on 72's. Here's a link to a matching set of 6's from a 72 (according to the seller). Your wheels should look like these
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 08-29-2008 at 10:11 AM.. |
bonus they are the right ones , pulled all the wheels off the car cleaned the inside and found the codes to be 6j 15 with 91136102000 number and date on the inside 472 so i guess thats 4th month 1972.
Due to the car having an sc converstion cira 1980 i need to get all the correct stuff back on and all the sc stuff out the door . Luckly it seems that all they did was mess up the front and rear clip , add sc bumpers all around and sc hood and rear lid .
I think you have steel SC flares on the back. I checked them a couple of weeks ago because I initially thought they were glass. You should have an original non deep dish 15X6 in the spare compartment too, leaving you only one to source.
'72 911 T/E Silver Targa |
