Free minder
Aurel's Avatar
Resistor spark plugs
In my rebuild (78 3.0L SC), I used NGK BPR5EY spark plugs, and my cylinder#6 does not fire well. I initially accused the spark plug as the culprit, because it had a 5 kohm internal resistance, about twice the resistance of the wire. Then, I discovered that this resistance is there by design, to prevent EM interference with computer engine management. Now, my SC does not need that, as it does not have a computer. So, I was wondering if I should change my spark plugs to low impedance ones, and can these resistor spark plugs be causing problems on a SC?
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 08-29-2008, 07:17 AM
Max Sluiter
Flieger's Avatar
If you don't need the resistor to prevent radio noise that would cause static on a sound system or EMF/radio frequency interference with a computer, then put in non-resistor spark plugs. If you can get some copper plugs in the proper heat range that have no resistor, run those and you will have slightly hotter spark and less heat stress to cause wear on electrical components. Your plug electrodes may wear out slightly faster.
All of this is in the small marginal gain area. You probably won't feel a difference between new plugs whether they have resistors or no.
Old 08-29-2008, 10:22 AM
Aurel,
"Flieger" is spot-on,....
You don't need (or want) resistor plugs on an SC since you already have RFI suppression in the plug connectors since these have an internal resistor.
Use plain old copper Bosch or NGK plugs and make sure your plug wires/connectors are in perfect condition.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-29-2008, 10:47 AM
Originally Posted by Steve@Rennsport View Post
Aurel,
I have a Porsche Spec book and it says to use Bosch WR5DC or WR5DP plugs. I was led to believe these plugs are resistor types. Can someone explain why Porsche recommends them but others say don't?
I am using a set of Magnecors (8.5mm) and the WR5DC's, is this combination not good and if so am I loosing some power or engine response somewhere because of it?
Old 08-29-2008, 11:05 AM
Come spark plug wire replacement time, you can also use stranded copper or stainless conductors, not the more fragile radio resistance conductors. The service life of metal core wires depends on the integrity of the insulator not the conductor.
Sherwood
Old 08-29-2008, 01:47 PM
Bill Verburg's Avatar
A resistance is placed in each sprk plug circuit to shift the RFI generated to a frequency that doesn't interfere w/ electrical equipement k=like radios.
It's interesting to note that thrugh '81 no resistor plugs were speced and '82-83 resistor plugs were specd. I know that on my '76 the resistance was in the connector so you could use steel core wire w/o concern. I also don't see a change is wire or connectors for the '82-83. It's quite feasible to use 2x the resistance w/o issue, that is until a combustion issue stresses the system at which point it won't fire as well.
Bill Verburg
Old 08-29-2008, 01:52 PM
Wer bremst verliert
JohnJL's Avatar
Your original question was regarding a poor-firing cylinder, what do you mean by "doesnt fire well?" Is it rich or lean? Are you using CIS or carbs? Did switching plugs fix the issue?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 08-29-2008, 02:14 PM
Free minder
Aurel's Avatar
Well, I swapped in a new plug, and it did not solve my problem. From the look of the old plug (beige), I would say it was running lean. Now, It sounds like I have leak in there, exhaust or head leak. The car is due for valve adjustment and retorquing head bolts, so hopefully I will find out the problem then. I have CIS. It is not backfire or misfire , just pop pop sound of a leak.
Aurel
Old 08-29-2008, 05:15 PM
Free minder
Aurel's Avatar
Doing my valve adjustment, I found one intake valve very loose. I still have the other side to do, but I hope that was my problem.
Aurel
Old 09-01-2008, 05:01 AM
