pr944may's Avatar
The serial number indicates that it is a standard ROW 2.7 911, which would not have come with the flares on the rear. Rear flares were standard on all Carreras from 1974 to 1977.
JR
Thanks for the imput I am in the process of learning about this car. I just took the plugs and they are w5dc but what I find are wr5dc are they the same? which should I use?
Albert
911 SC 1983 :
Old 09-01-2008, 09:40 PM
The wr5dc might work. The "r" indicates that it is a resistor plug. It is there to prevent pulses of energy traveling back up the plug wires when the spark plug fires. It prevents RFI interference with other electronic components.
In a 1977 car, you probably don't need them, as you don't have any sensitive computers, although you might get some noise through your radio if you have no resistance in either the plugs or the plug caps. Porsche also put resistance into the spark plug caps, so if you are running those, you don't need resistors in the plugs. If you are running non-standard plug caps that lack restistance, the resistor plugs are probably OK. Some cars run fine with both.
I did a quick google search and found lots of places listing the w5dc plug for sale, so you could run the old style plug if you want to.
JR
Old 09-02-2008, 05:14 AM
IROC's Avatar
Originally Posted by chris.817 View Post
Okay. The report.... Drum roll.... POS!
Rear sway bar is missing too.
Just for a bit of information, most non-US cars in '76/'77 did not come with rear sway bars. Front and rear sway bars were pretty much a US-spec only thing and were optional on RoW cars. Most RoW cars came with a 16mm front bar and no rear bar.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-02-2008, 07:04 AM
pr944may's Avatar
Mine has front and rear sway bars but don't know the diameter.
Albert
911 SC 1983 :
Old 09-25-2008, 10:22 PM
