pr944may's Avatar
Help Identify the type of 911
Recently I bought a 911 from the father of the original owner an Army Captain that herself told me she bought it in Germany. The car is in excellent condition in and out everything originall. What I learned is thanks to all Fellow Pelicans. Here are the facts.
2.7 engine code 6372802
vin. # 9117311396
Targa, Turbo Look Spoiler
No gas pump, No Air Condition
Fabric Interiors, manual windows
radio antenna at driver side fender
alternator 5 blade fan # 9011061015R
Reinforce crossmember as carrera
front and rear stabilizing bars
5 SPEED, stnd.
flares in back (someone said there where sc flares
Manuals go up to 74 2.7 and 78 and up 3.0 so What should I used
Only manuals that I have are: Haynes and 101 Projecs and you, Masters!!!
Albert
911 SC 1983 :
Old 09-23-2008, 05:21 PM
Bill Verburg's Avatar
'77 RoW 2.7 911/81, 165hp cis
vin. # 9117311396
'77 RoW targa, the flares are not oe(they appear to be SC/Carrera), neither is the spoiler(which appears to be a 3.3 turbo), the head lights have been converted to '70s US spec as has the front bumper position/turn signal lights, can't tell about the rear position/turn lights
Bill Verburg
Old 09-23-2008, 05:34 PM
pr944may's Avatar
Bill: Thanks for the imput anf sharing light over specs. The rear lights works as expected form a US car. Only minor items has being fixed with Pelican parts of course!
One last Question: It is a 911S or 911?
Albert
911 SC 1983 :
Old 09-23-2008, 05:59 PM
f3nr15's Avatar
This old post from Grady might help a little:
Originally Posted by Grady Clay View Post
Your 7=digit ’75 engine number should have the form:
*6X5xxxx*
where:
6 = Engine design, 6-cylinder engine
X = numbers 1-7 (see list below)
5 = Model year 1975
xxxx = Sequential serial number usually starting with 0001. Exceptions: Starting with 9001 = engine for Sportomatic.
X = 1, 911, Type 911/41, (or Type 911/46 for Sportomatic)
X = 3, 911S, Type 911/42, (or Type 911/47 for Sportomatic)
X = 4, 911S/Carrera USA, Type 911/43, (or Type 911/48 for Sportomatic)
X = 5, 911S/Carrera California, Type 911/44, (or Type 911/49 for Sportomatic)
X = 6, Carrera 2.7 (MFI), Type 911/83
X = 7, Turbo 3.0, Type 930/50
Best,
Grady
Although, Grady left out the "X = 2..." line.
Regards,
Peter
1992 928 GTS
1993 964 Carrera 2 Coupé
Old 09-23-2008, 06:33 PM
And then there's this page:
http://www.0-100.it/porsche/welcome/welcome_italiano.htm
Go to the menu item "NUMERI DI TELAIO PORSCHE 911"
It's in Italian, but still theres lots of info to be gained.
/Nimskov
Old 09-23-2008, 10:20 PM
No sleep 'til... BROOKLYN
flatsixjunky's Avatar
pr944may
You should consider upgrading that fan to an 11 blade one, in PR temps are playing against you. And if you can afford it a carrera oil cooler. Just my 2cents.
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 09-23-2008, 10:54 PM
Air Cooled Addict
Joe V's Avatar
Albert,
Perfect color for Colegio!!!
Joe V
'84 Schwartz 911 Carrera 3.2
'91 Specialized S-Works M2 - Gone but not forgotten
'12 Trek X-Cal : American Classic - XT brakes/shifters/derailleurs - carbon goodies
'13 Trek Madone 5.2 stockish
Old 09-24-2008, 03:15 AM
For '77 J series carsthere was no RoW S
the RoW line up was; 911, Carrera 3.0, Turbo, your's being a RoW was just a 911 w/ 911/81 engine and 915/60 5 speed
In the US the lineup was; 911S, turbo, the 911S used 911/85 engine and 915/61 trans
Both 911/81 & 911/85 are rated 121hp@5800, 235ft-lb@4000, 8.5cr
Bill Verburg
Old 09-24-2008, 04:04 AM
Make sure it doesn't have the exhaust thermal reactors under the engine (don't know on ROW cars - US only, I think), and you may get by w/ the 5 blade fan (11 blade is a really good idea, though). Make sure you get the correct diameter 11 blade (couple different sizes).
Don't know if the '77 ROW cars had front oil coolers or not. Look inside the RF fender in front of the tire by the horns. If it has a trombone cooler, it might be adequate depending on your driving style.
Old 09-24-2008, 06:59 AM
pr944may's Avatar
It does not have thermal reactors and yes it has trombone cooler. Some time ago a Pelican friend toll me to strip the heat exchanger which I did. My next proyect is to buy a 11 blade fan and H4. I use this car only once a week on sundays if it not raining. Just take of the top and enjoy the sun and wind
Albert
911 SC 1983 :
Old 09-25-2008, 09:04 PM
pr944may's Avatar
Originally Posted by flatsixjunky View Post
pr944may
Thats me next project! the highest temp that it has run was 85- 100 as the dial shows
Albert
911 SC 1983 :
Old 09-25-2008, 09:07 PM
pr944may's Avatar
Originally Posted by Joe V View Post
Albert,
At the begining I did not like the color but because is original, and almost all are red, gray, black. It calls the attention. The only bad thing for a cop it is easy to spot!
Albert
911 SC 1983 :
Old 09-25-2008, 09:11 PM
pr944may's Avatar
Thanks for the info It's being of great help!
Albert
911 SC 1983 :
Old 09-25-2008, 09:16 PM
f3nr15's Avatar
In a similar vein, here is another terrific site, this time in German, but easy to navigate through and decipher:
http://www.elferhelfer.com/fzident.htm#
Regards,
Peter
1992 928 GTS
Old 09-25-2008, 09:50 PM
