jj4u3's Avatar
headlight problem
I can be driving down the road at night and my headlights will sometimes burn brighter for a minute or two and then burn dim for a while. Doesn't matter if I rev up the engine or not? I recently blew a fan belt and replaced it. Could it be that I don't have it tight enough or do you think maybe a short? 72 911T with 3.2
911 - 1972T
Old 09-23-2008, 05:38 PM
dshepp806's Avatar
not familiar w/ your year,..but is the regulator OK?
best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-23-2008, 05:42 PM
Cooper911SC's Avatar
Likely voltage regulator going. Check the alternator output at the battery while car is running. It should be around 13.8V or so. Not much higher.
Mine stuck and overcharged the system...ended up burning out my headlight bulbs!
Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 09-23-2008, 05:52 PM
jj4u3's Avatar
thanks it is going to the shop for another problem Thursday. I will have them check the voltage regulator and the altenator output. you guys are great, thanks
911 - 1972T
Old 09-23-2008, 07:07 PM
Regis turd ab user
Check ALL of your ground straps.
Old 09-23-2008, 07:14 PM
