Side rubber replacement help
G'day guys,
Is there a trick to replacing the side rubber mouldings?
The ones below the doors.
I dont think it will slide back on. It stops after about 12".
I haven't had any luck trying to clip the bottom into the groove either.
Cheers, Col.
Boilermaker......another young man in an old man's body.
Col.
3-'74 911 targa.
Old 09-19-2008, 08:04 PM
4flyboy's Avatar
Subscribed.......................I need to know too Col.!
Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 09-19-2008, 08:08 PM
old man neri's Avatar
Are you talking about the long rubber strip that goes between the body and the rockers? If so I recently had to do it. I started at the front of the car and slid it all the way back. I coated the inside of the rubber and the metal work in dish soap. It worked great. I did it with both the top and the bottom in their respective grooves.
Old 09-19-2008, 08:26 PM
KY works the best it is very slick, water based and evaporates.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 09-19-2008, 08:48 PM
To the lady behind the counter in the sex shop, "Can i have some lovin' lube for my Porsche please?"
Oh dear!
Thanks guys.
Col.
3-'74 911 targa.
Old 09-19-2008, 09:05 PM
It really works, I struggled for about two hours with dish soap trying to get those rubber strips on and, my neighbor told me to try some KY. 10 minutes later both sides were on.
....everyones doin it.
Old 09-19-2008, 09:09 PM
Recreational User
porschenut's Avatar
A few years ago I read an article that said K-Y jelly was the #1 most shoplifted item in stores, because no one wanted to go through the checkout line with it.
I just used a little white lithium grease on the runners before sliding the rubber strips on. Took about 10 seconds per side.
Old 09-20-2008, 08:50 AM
crustychief's Avatar
KY also works good for shaving.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 09-20-2008, 11:34 AM
efhughes3's Avatar
Spray silicone works great. They'll be on in 30 seconds. No residue to contend with.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 09-20-2008, 12:16 PM
