Can someone explain why this is happening?
When I first start my car ('82SC) in the morning, it has power and pulls like it's possessed, but after it gets warm it seems to lose that pulling power. I bought the car a month or so ago, and I've been planning to do a valve adjustment soon, could that be it?
Old 09-19-2008, 02:16 PM
sudo apt-get purge 930
equality72521's Avatar
I'd suspect your WUR is out of spec. Sounds like it may be going lean when warm. What temps are you seeing when the engine is hot? I'd throw some gauges on and check your cold and hot pressures. Do a search on checking pressures and you'll find plenty of threads on how to do this.
--clutch-monkey
Old 09-19-2008, 03:34 PM
Temps tend to vary but generally they are between the second and third white bar. Can the WUR be adjusted or is it a replace item only?
Old 09-19-2008, 06:25 PM
Designer King
Paulporsche's Avatar
WURs can be adjusted, rebuilt, or replaced. If you search WUR and my name you will see a recent thread in which I went through the WUR scenario.
You need to first verify that it is your WUR. You can do that w/ a fuel pressure gauge.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-19-2008, 06:30 PM
