Throw it on the ground!
How do you seperate alternator from fan housing?
It's been so long since I had the alt & fan housing out of my car that I don't remember if I seperated the two. Now working on my replacement engine and cannot seperate the fan housing & altenator. Tried tapping on the back side and broke off a piece of the alum casting on the alt which fell down into the alternator and is now rattleing around
![]() Looks like taking the alt in to be bench tested and rebuilt as necessary is no longer an "option" Need to seperate to get fan housing powder coated. Any tips....not doing so good on my own. Should I just let the alt shop deal with it? BTW, the Alt is a Bosch Valeo Mfg in France unit believed to be orig - engine has 58k on it. (Nope - its a remanufactured unit) ![]() Half moon alt housing chip in center of this photo:
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 09-23-2008 at 08:31 PM.. |
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
If you dont care about the alternator, like i didnt, soak the housing and alternator in liquid wrench. Wait 10 minutes then grab the housing, and slam it down on the concrete sidewalk so the alternator shaft will hit from the back side of the housing/alternator. Be careful though, you can crack the magnesium fan housing if your not careful. My alternator was wearing out, so thats why i chose this method. I replaced it with a refurb paris rhone alternator of ebay, and ordered a valeo voltage regulator and slapped it on the paris rhone, no problems since, year went by so far. I've heard that paris rhone alternator's vr's were buggy so thats why i got the valeo regulator.
EDIT: This is, of course, after u remove the alternator nuts that hold the alternator to the housing... hehehe...
1984 Porsche Carrera Cabriolet - sold, regrettably 2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably 2005 Mercedes C230 Kompressor Sport Sedan - now... Last edited by dimeified; 09-23-2008 at 07:19 PM.. |
I have done this MANY times on two different fan housings.
The easiest and safest way is to let gravity to do the work. Tapping sometimes works, but using gravity works better. Check out that link posted by MBAtarga.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Thanks guys....did the search and found this: John Walker is a genius!
Got it seperated in less than 1 minute! jeeze, somebody's still pounding on the studs! let gravity and inertia work for you. fold a shop rag and lay it on the concrete. take the housing, fan facing down, and rap the edge on the rag a couple of times, turn it 180° and rap the other side. pretty soon the alternator will be out. __________________ www.johnwalkersworkshop.com/ 206 789 6800 7613 greenwood ave n seattle wa 98103
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Ain't it great when a plan comes together.
![]() When I removed my alternator to have it rebuilt I tapped on the studs for a few seconds. I set the entire unit down on my workbench to get rid of one beer and get a cold beer. When I picked up the fan housing the alternator almost fell out. Done!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Senior Member
Yes, JW is a genius.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
