Throw it on the ground!
How do you seperate alternator from fan housing?
It's been so long since I had the alt & fan housing out of my car that I don't remember if I seperated the two. Now working on my replacement engine and cannot seperate the fan housing & altenator. Tried tapping on the back side and broke off a piece of the alum casting on the alt which fell down into the alternator and is now rattleing around
Looks like taking the alt in to be bench tested and rebuilt as necessary is no longer an "option"
Need to seperate to get fan housing powder coated. Any tips....not doing so good on my own. Should I just let the alt shop deal with it?
BTW, the Alt is a Bosch Valeo Mfg in France unit believed to be orig - engine has 58k on it. (Nope - its a remanufactured unit)
Half moon alt housing chip in center of this photo:
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 09-23-2008, 06:23 PM
MBAtarga's Avatar
alternator removal
Mark
'83 SC Targa - since 5/5/2001
Old 09-23-2008, 06:33 PM
If you dont care about the alternator, like i didnt, soak the housing and alternator in liquid wrench. Wait 10 minutes then grab the housing, and slam it down on the concrete sidewalk so the alternator shaft will hit from the back side of the housing/alternator. Be careful though, you can crack the magnesium fan housing if your not careful. My alternator was wearing out, so thats why i chose this method. I replaced it with a refurb paris rhone alternator of ebay, and ordered a valeo voltage regulator and slapped it on the paris rhone, no problems since, year went by so far. I've heard that paris rhone alternator's vr's were buggy so thats why i got the valeo regulator.
EDIT: This is, of course, after u remove the alternator nuts that hold the alternator to the housing... hehehe...
1984 Porsche Carrera Cabriolet - sold, regrettably
2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably
2005 Mercedes C230 Kompressor Sport Sedan - now...
Old 09-23-2008, 07:08 PM
mca mca is offline
mca's Avatar
I have done this MANY times on two different fan housings.
The easiest and safest way is to let gravity to do the work. Tapping sometimes works, but using gravity works better.
Check out that link posted by MBAtarga.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 09-23-2008, 07:13 PM
Thanks guys....did the search and found this: John Walker is a genius!
Got it seperated in less than 1 minute!
jeeze, somebody's still pounding on the studs! let gravity and inertia work for you. fold a shop rag and lay it on the concrete. take the housing, fan facing down, and rap the edge on the rag a couple of times, turn it 180° and rap the other side. pretty soon the alternator will be out.
www.johnwalkersworkshop.com/ 206 789 6800
7613 greenwood ave n seattle wa 98103
Mark
1987 911 Coupe
Old 09-23-2008, 07:36 PM
Ain't it great when a plan comes together.
When I removed my alternator to have it rebuilt I tapped on the studs for a few seconds. I set the entire unit down on my workbench to get rid of one beer and get a cold beer. When I picked up the fan housing the alternator almost fell out. Done!
Old 09-24-2008, 03:57 PM
Senior Member
Superman's Avatar
Yes, JW is a genius.
Mocha 1978 911SC. "Coco"
Old 09-24-2008, 04:39 PM
