jlex
Guest
Posts: n/a
Post head temp sensor
I'm going to replace my old style head temp sensor ('85 Carrera) this summer. I'd hate to cut the wire in case I need it for a spare, emergency part later.
Has anyone out there removed theirs without using the special, slotted socket? I'd like to know the mm size of the sensor, also. Is there enough room for a crowfoot wrench to do the job? Thanks.
regards,
jlex.
Old 04-02-2001, 11:16 AM
john walker's workshop
Guest
Posts: n/a
Post
old style is 13mm, new is 14mm. i just bought a snap on tool that looks like it will work without cutting the wire. #FRXM14. haven't tried it yet. the old ones have been proven to be problematic, so i would toss it.
Old 04-02-2001, 11:39 AM
Jorgeman
Guest
Posts: n/a
Post
Also, the new temp sensor will be two wire
rather than the original one wire. The old sensors depended on their screw threads to provide the ground connection but being of dissimilar metals, they corrode and lose their conductivity. The new one includes a ground wire.
George
86 911T
Old 04-02-2001, 03:13 PM
Throw it on the ground!
Wow kinda spendy for a one-time DIY use at $55! Anyone fabricate one using a deep socket and a grinding wheel to cut a slot for the wire?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 09-24-2008, 06:12 PM
Make Bruins Great Again
Por_sha911's Avatar
I bought a $3 deep socket and ground a slot using a cutting wheel. It took a little while to get the slot the right size but it worked fine and was a whole lot cheaper than that thing.
Joe
Old 09-24-2008, 06:24 PM
notfarnow's Avatar
That's what I did... 2 minutes using an angle grinder.
Crude but works great
'03 Carrera 4s
+ a whole bunch of boats
Old 09-24-2008, 06:32 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 on my Ghetto Tool but I cut/grinded like the previous pic.
Warning it is tighter than a heck and beware you will get alot of cuts.
Remember to use a Jack Stand for safety.
Break a Leg!
'85 Carrera Targa
PCA/POC
Old 09-24-2008, 11:51 PM
Large Registered Member
PatrickB's Avatar
George
86 911T
Don't be worried if you can't locate the new style 2 wire. The old set up only lasted 20 years in most cars...
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 09-25-2008, 12:20 AM
Break a Leg!
Won't be a problem - engine is out!
Mark
1987 911 Coupe
Old 09-25-2008, 05:05 AM
DRACO A5OG's Avatar
Nice
'85 Carrera Targa
PCA/POC
Old 09-25-2008, 03:23 PM
Just saved $55! Works great.
Mark
1987 911 Coupe
Old 09-25-2008, 07:55 PM
3.2 CAB's Avatar
Yep, you can make up an entire set, of shop made, deep sensor sockets, for what the cost of just one tool truck socket would cost.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 09-26-2008, 10:56 AM
burgermeister's Avatar
You don't need a special tool to get the old one out. Just clip the wire and use a deep socket.
Looks like you made an install tool already. I did the same.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-26-2008, 02:04 PM
