Daviboy's Avatar
How do I set the mixture properly on my 911 CIS (non lambda)motor?
Guys,
I know I am going to take a lot of flak here so am hunkering down for the barrage. I have an 82 SC without lambda sensor as I have headers and no O2 sensor. Everywhere I read (here and Rennlist forum) all the advice for setting the mixture on the motor is for cars with lambda.
I think I basically understand the CIS system however how do I set mixture after an air-box replacement?
Davy
82 911 SC Targa Sold
12 Audi A5 Sportback 3.0 TDI Quattro
03 996 C4S
Old 09-26-2008, 01:17 AM
RETIRED
Joe Bob's Avatar
Best is to make sure your fuel pressure is good, get the long hex key and use a smog box for the tail pipe.
2012 ML350 3.0 Turbo Diesel
Old 09-26-2008, 03:56 AM
T77911S's Avatar
i set mine by making small CW changes until it surged at idle, then turned it CCW about half a turn then CW to the last place it did not surge. drove it and if the RPM's dipped down when i let off the gas, then i would do the CCW then CW and make it just a Little leaner until the RPM's dont dip. i had it checked later and it was dead on 3%. basically, set it as rich as you can without idling problems.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-26-2008, 04:52 AM
find a shop with an exhaust analyzer and set it to 3-3.5%.
206 637 4071
Old 09-26-2008, 05:14 AM
Daviboy's Avatar
Thats it stick an O2 sensor in the tail pipe and adjust idle mixture till 3-3.5% reading achieved?
Davy
03 996 C4S
Old 09-26-2008, 06:04 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Yep thats it...I took John Walker's advice on this many years ago. Back then he also recommended a timing setting of 5 degrees BTDC. JW is one of the real guru's on the board, we are all glad to have him as a resource, IMHO.
Also know that as you adjust the CIS mixture you will change the idle RPM. Changing the timing will alter the idle as well. So, I set my timing first, then adjust the CIS keeping the idle around 1000 RPMs. After getting the A/F the way you want it, dial down the idle to 950 or so... At least that the technique that works for me.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 09-26-2008, 08:53 AM
Daviboy's Avatar
Kemo,
Thanks just cannot believe it is that easy, this I will attack on my own no problemo. Excuse my ignorance but what does BTDC mean....doh my guess is Before Top Dead Center, am I correct am I am I? If so how is that done??? Sorry
Davy
03 996 C4S
Old 09-27-2008, 12:25 AM
Correct on the BTDC. To set it you need a timing light and adjust your distributor by loosen the mounting nut and rotate it slightly to set it at 5 deg, btdc at 950 -1000 rpm.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 09-27-2008, 12:38 AM
Somatic Negative Optimist
Gunter's Avatar
Guys,
Even though you don't have a sensor, the rest is still Lambda unless you removed other components?
Set the mixture as advised by others; it takes a few tries between mixture screw and the fast-idle screw.
Set the timing at 5 deg BTDC with vacuum disconnected at ~950 RPM.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-27-2008, 10:32 AM
Scott R's Avatar
If its still has the lambda gear and no O2 sensor you need to get it sorted. If you search under my name you will see two dyno runs, one with the O2 sensor hooked up and the mix set per the factory. The second is disconnected and set to 3.5%, the 3.5% run is a mess, AFR's are all over the place and power is down.
With the sensor connected and all of the equipment working the AFR's are near perfect and the power is much better. The default operating mode of the frequency valve appears to cause this.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 09-27-2008, 01:06 PM
Gunter,
Could you be more specific about what other component/s needed to be removed? And why? Thanks.
Tony
Old 09-27-2008, 01:12 PM
Daviboy's Avatar
Gunter mine is a euro ROW model therefore no lambda equipment or sensor. I would appreciate a post with pics of setting timing if possible!
Davy
03 996 C4S
Old 09-27-2008, 10:40 PM
Gunter's Avatar
Originally Posted by boyt911sc View Post
Gunter,
Tony
On a 1980-83 US 3.0 with Lambda, a lot of people use the CIS from 1978-79; it has larger intake runners and no Lambda.
No brain, no Frequency Valve but still has AAR, AAV, Decel.Valve, TTS, CSV.
Old 09-28-2008, 08:52 AM
Black and Blue
Kemo's Avatar
I dont have any pics...but a good thing to do would be to find the markings for setting the timing and make sure you can clearly see them before you hook up the timing light.
just to the right of the Z1 mark, you should see another tickmark, possibly with a 5. This is the 5 Deg mark and thats what you line up to the tick mark just above the wheel when you spin the distributor to adjust the timing. Some timing lights allow you to preset the light with a certain advance or retard. If you are using the 5 mark to line up, make sure your timing light isn't set up for advance.
I think now would be a good time to suggest Waynes 101 Projects book. It has great pictures for doing this. I also think some good pictures could be found searching the threads for valve adjustment, as you need to use the markings for this procedure to get the #1 cyl to TDC.
Kemo
Old 09-29-2008, 08:01 AM
Daviboy's Avatar
Kemo,
Thanks I have Waynes book coming in a shipment along with a new airbox + gaskets and ruubers, front rotors and pads + caliper rebuild kit, clutch cable, pedal bushing kit, headlight relay kit, factory short shift kit + new bushings, valve cover gaskets, oil filter + seals, and some other goodies. So I will be leafing through his book quite extensively in the weeks to come. I am sure the wife will be charmed but what the hell it keeps me out of trouble.... well other sorts of trouble lol.
Davy
03 996 C4S
Old 09-29-2008, 11:51 PM
Black and Blue
Kemo's Avatar
nice...i agree.
let us know how things turn out with the projects and good luck.
Kemo
Old 09-30-2008, 08:32 AM
otto in norway's Avatar
Sorry if I'm intruding here...
What if you want to adjust the mixture without the cat installed? (I have a pre-muffler installed instead)
What will the correct O2 sensor reading be then?
Otto
Old 09-30-2008, 08:49 AM
MBEngineering's Avatar
HI Daviboy
If you a 81/82 engine then you need to look at this chart, if it is NOT US spec, as the CO% will be to high at 3% and the engine will hunt at idle;
has your engine a air pump on the L/H side of the engine ne'er the dist, if so remove the belt before adjusting the CO%, and always adjust the CO% from weak to rich as the small relay arm in the air flow sensor plate will be tight and some times sticks.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 09-30-2008, 08:58 AM
holtjv's Avatar
Oh and if you buy the pelican "T" allenhead tool for adjusting the mixture you'll probably have to cut down a bit--too high for my 79, anyway. Or find another allenhead.
Good luck and have fun with Wayne's book--should pick up a Bentley, too. Between the Board, Bentley, and 101 you ought to be able to figure anything out.
Warren Hall (Early S Man), 1950 - 2008
2006 Tri D675 Scorched Yellow
2006 Ducati Sport Classic mono SOLD
1979 SCWDP #0020 Talbot Yellow SOLD
Old 09-30-2008, 01:16 PM
Daviboy's Avatar
Originally Posted by MBEngineering View Post
HI Daviboy
regards mike
Mike,
My car is non US it a ZZZ ROW car. Is there any way you can scan and send me that chart, it is ompossible to read from the picture? If so send to davy_1010@yahoo.com
Davy
03 996 C4S
Old 09-30-2008, 11:36 PM
