930 trans. identification
I am trying to i.d. this trans. for a project that I am working on. any help would be appreciated.
Thanks, Matt ![]() ![]()
Matt Cooley 1974 911 |
Because of the amount of ground off material on the number boss, that appears to be someone's idea of a number. 930/36 indicates a 4-speed Turbo trans (1985-'88), but the rest of it I can't help with. The "2" might be half of a "12", which would indicate that the diff is equipped with LSD (Limited Slip Diff).
Keep the Shiny Side UP! Pete Z. |
Thanks for the info Pete, the literature I have also confirms that a 930/36 is from a '85-'88 turbo. It doesn't appear to be LSD, when turning the output flange on one side the other side rotates in the opposite direction. In any case I don't need it for the project I'm doing, so I will list it in the parts for sale section. Any idea on value?
Matt
Value? Couldn't even guess!
I'll wing it.
