Fuchs part number
Can anyone identify what car this fuchs was meant for? I have never seen the second set of numbers in all the places I looked:
#911.381.020.11 I have only seen 361 in the second set. TIA.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
the # system is based on original car use(in this case 911) . component section(38x is 944 transmission section) all wheel and wheel related parts are xxx.361.xxx.xx or xxx.362.xxx.xx
![]() However, I asked this question because of this photo--tell me what you think: ![]() Comparing the "8" with the "6" below it, the open part of the 6 is not as round as the upper, closed part of the 8 so even if the 8 is a deep strike on the wheel, the upper closed circle would be flatter--wouldn't it?
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 09-28-2008 at 09:36 AM.. |
xxx.361(2).xxx.xx the exception is generic parts like bolts, nuts, rubber stems there is no oem 911.381.xxx.xx anywhere that may be a casting # or an aftermarket wheel
sudo apt-get purge 930
Looks like someone at the factory grabbed an 8 instead of a 6 when stamping it.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
