911Etarga's Avatar
Tach problems
I recently got my tach rebuilt by North Hollywood Speedometer, and I looks and works great. The other day, it started acting up. When I start the car, it works. After about 3 minutes, it stops working.....I put in another tach, and the same thing happened. When it is working, the needle wil not go past 3500rpm, even when revved much higher than that.
Any Ideas???
Thanks in advance.
'71 911E Targa
Old 10-03-2008, 11:36 AM
I have lost control of my rev counter twice before, by which I mean it does not reflect what the engine is actually doing. The first time it was a faulty alternator and the second time a faulty regulator. Check your charging voltage and see if it is correct.
Ian
Old 10-04-2008, 12:51 PM
Monkey Butt Forespin
84_Carrera's Avatar
I am also having issues with my tach, which was rebuilt by NHS back in May, and didn't work right upon receipt. I was told by NHS that 1) well, it's then likely the DME unit; after checking & seeing a signal on the tach lead to the tach when the tach was failing (reading 0), I was told 2) that oh, well, then it's probably the voltage regulator.
I replaced the Alt back in '05. So I replaced the regulator today (even thought I was not seeing anything far out of ordinary in charging), and I'm still getting the issue. I'm sending my tach back to NHS Monday. It is my opinion that it's inside the tach itself.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 10-04-2008, 06:11 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
Ian
second the charging issue i just went through the same thing and it was a voltage regulator
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 10-05-2008, 01:15 AM
