Jim Williams's Avatar
Anyone know on what engine this ignition distributor belongs?
I found this in one of my parts boxes. 0 231 169 008. I've looked though all the references I can find including the Bosch Ignition catalog, and can't find anything. Maybe for a Euro engine? The range of neighboring numbers is around a '71 - '73. Takes a vacuum retard pot, which I have, it's just not mounted in the photo.
I post the photo just so someone doesn't ask, "Are you sure that's an 8 and not a 6?"
Thanks for any clues.......
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 10-11-2008, 03:20 PM
maybe a 1973 911T
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-11-2008, 03:37 PM
www.pelicanparts.com/showthread.php?t=374643
also the Tech Spec booklet shows all '72, '73 dizzys same curve
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-11-2008, 03:48 PM
gearhead
'72 911e
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 10-11-2008, 03:55 PM
Thanks to all that responded....
After looking again at the little spec book for the '72 '73 models, I found a line I missed earlier ; it shows the 008 as starting with the '73 T, and says they can be installed in the '72 as well, in place of the 003. The '72 E shows an 004, with the '73 E using the 009.
Thanks again for the replies.
Jim
Old 10-11-2008, 05:32 PM
I use 0.231.184.004
didn't know it came on '72E.
I thought it was only used on '74-'76 Euro Carrera and 2.7 RS, '73 Carrera.
I set 10 deg initial BTDC and it totals at 35 deg. Works great for my street engine.
It costs brand new $300 at www.********.com
Pelican Parts will match any price. Comes new with cap and non-rev-limiting rotor.
advance curve on p48 of '72,'73 Tech Spec book
ie:
this thread has Warren and Sherwood on distributors
Distributor Question
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-12-2008, 04:32 AM
Originally Posted by RoninLB View Post
I use 0.231.184.004
ie:
According to the Bosch Ignition catalog, the 231.184.001 is the distributor specified for the '77S. The 231.184.004 is specified for the '74 and '75 2.7 Carrera. The '72 E uses a 231.169.004. Notice the difference in the middle three digits.
Jim
Old 10-12-2008, 09:24 AM
