brake light switch replacment
hey all, My 87 targa recently had its brakelight switches go out. NOt sure if it is one or both, so I plan on replacing them both. They are the two spade connector "narrow" ones. Pelican sells the wide switches and says there is an adaptor for the narrow ones, but I can't seem to locate it on the website. any info would be helpful...or a line on where to get the narrow ones.
thanks
Carl F
2000 Ruby Red Dodge Stratus with high performance racing stripe SE edition WTF? (sadly gone, but not forgotten)
1997 HOnda Accord "Shaggin Wagon"
1987 All black Targa
1998 Lemond Zurich/Dura Ace
2005 Jamis Dakar Sport
2006 Lemond Reno
2 DOgs , 2 Cats, Shi@ton of fleas
1 Cool as Hell Wife that tolerates my stupidity
Old 10-14-2008, 03:02 AM
kbruz's Avatar
I'm not aware of an adapter, so I made my own
kb
mercedes GLK350
2009 boxster s
86 targa
Old 10-14-2008, 10:27 AM
aj88cab's Avatar
This is another option:
Brake light switch connector spacing problem
Good Luck,
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 10-14-2008, 10:48 AM
myamoto1's Avatar
a better solution is to get the BLSAS relay from Draco A50G. Here's another couple of threads for you to check out:
One or Two Brake Light Swiches???
Brake Light Switch, Again?
Josh
85 M491 Coupe - "Fat Bastard"
Old 10-14-2008, 11:25 AM
rnln's Avatar
I used to add 2 pieces of wire before I got the Arc Suppressor. You might want to read this thread. There are many threads about this. if you want to read more, you can search on "Brake light" or "Arc Suppressor".
http://forums.pelicanparts.com/porsche-911-technical-forum/434599-one-two-brake-light-swiches.html#post4227196
Fat butt 911, 1987
Old 10-14-2008, 11:27 AM
