Friend of Warren
First mechanical problem in years!
My '86 has been dead reliable. Even this problem is minor. Go to turn on the wipers and on low they will not work. Switch to high and they will eventually work and then I can switch to low and they work. If I pull in on the lever the washer/wiper works. Is this a symptom of the wiper switch going out and needs replacing or just a good cleaning of the contacts? Thanks all.
Kurt V
Old 10-17-2008, 12:00 PM
Barrpete's Avatar
I had a similar problem. Cleaned the switch with and all was good.
Windshield wipers suddenly don't work
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 10-17-2008, 12:05 PM
Friend of Warren
Thanks Pete! Good weekend project.
Kurt V
Old 10-17-2008, 12:41 PM
Barrpete's Avatar
It could still be the relay or the switch itself but cleaning it is easy - and cheap. You would not believe the amount of crud that came out of mine. I'm was surprised it worked at all.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
Old 10-17-2008, 12:52 PM
Sultan of Sawzall
rouxroux's Avatar
Also be sure to check your fuse block. I had one crack ever so slightly and all sorts of gremlins (wipers, brake lights, directionals, etc.) started to appear. All's well now!
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 10-17-2008, 01:38 PM
Friend of Warren
Pulled and cleaned out the switch with contact cleaner and it works perfect now. Took about an hour. Thanks!
Kurt V
Old 10-18-2008, 10:14 AM
Barrpete's Avatar
Ya gotta love it when the original parts work fine after 22 years with nothing but a simple cleaning. Try that with Ford or Chevy....
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
Old 10-18-2008, 08:27 PM
