Eye of the Toiger
matty74's Avatar
Can I use a 964 dizzy in a 3.0 motor?
I am doing another top end rebuild and want to go twin plug.
Can I use a 964 dizzy in a 1978 3.0 sc motor?
what modifications need to be done for this to work?
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 10-20-2008, 11:58 PM
Matt,
You must install a 964 crank gear to use the 964 distributor in your SC so that it rotates the correct direction and match the pitch of the gears.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-21-2008, 12:27 AM
Eye of the Toiger
matty74's Avatar
so I assume I have to split the case to install the crank gear?
Old 10-21-2008, 01:24 AM
