Pelican Parts Left Side Heater Block Off- DIY (No Can-No Clamp)
Really got tired of the can and clamp. Thread inspired by Tom .
Removed assembly, actually I did not have to pull the distributer.
30 Year old plastic ....
I used tin foil to form a basic shape;
Flattened the foil back out and used as a template on a sheet of thin alu from the hardware store;
Cut out the shape;
Shaped the alu and marked holes, made cuts and shaped;
Sanded the edges and fine tuned.
Painted and mounted;
Im happy. $13.67 and 3 beers.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 10-20-2008, 09:54 PM
E-85 sippin drunk
turbobrat930's Avatar
Let me the first to say...GOOD JOB!!! that looks very good! and to think they charge something like $80 bucks for one of those panels....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 10-20-2008, 10:57 PM
Nice job!
Old 10-21-2008, 03:16 AM
Designer King
Paulporsche's Avatar
Nice. Did you bend the alu by hand, w/ pliers, over wood blocks or what?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-21-2008, 04:43 AM
Friend of Warren
Very nice work!
Kurt V
Old 10-21-2008, 04:45 AM
JBO JBO is offline
How do you get any air flow through the heat exchangers when you do it like that (or do you have headers or does it not matter?). When I did the left side I ran the left side hose down to the left side heat exchanger, but have no flow through the right (passenger) side, and it does not run hot at all.
Old 10-21-2008, 07:44 AM
MBruns for President
JeremyD's Avatar
Excellent Job! and that gives me an idea to be able to use the Aluminium form to make a mold for me to fiberglass... (I am a fiberglassing fool)
Old 10-21-2008, 08:10 AM
3.2 CAB's Avatar
Yep, a roll of the aluminum, roof valley metal and a can of PVA, you could go nuts making molds. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 10-21-2008, 10:25 AM
Thanks for all the comments!
Paul, I bent it by hand to get the basic shape and then used small wood blocks and a hammer to get the exact shape and yes I used pliers too, the aluminum was pretty easy to bend by hand.
If you are thinking of doing this it's really not that hard, but buy enough back up aluminum, the first one I made was just about perfect and then I bent it flat again and it split so I used it as a template for the final one.
JBO, No flow to the exchangers, to do that you would need to back date to the older style left and right side covers that route the heat to the exchangers.
Old 10-21-2008, 12:59 PM
Damn! I had only seen those for 80$ + before. Looks like a good buy. But I would have missed out on the scrapes and cuts associated with the experience.
How is the fit?
Old 10-21-2008, 01:05 PM
Czar of C.R.A.P.
dfink's Avatar
Is the part small enough to trace to a piece of paper so we can all benefit from your hard work. Sounds like you have a nice template. I was just looking to order but I have the aluminum so will have to try.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 10-23-2008, 02:26 PM
thx for a great thread
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-23-2008, 06:40 PM
Designer King
snbush67,
I see you have MSD wires. Do you have a part number for that set? Have you had any problem w/ the fit? I had a set because I got an MSD CDI but the plug ends were so difficult to fit I swapped in an unused set of Fyrebraids I had lying around which have Beru ends. The fit is much better.
Paul
Old 10-23-2008, 07:35 PM
Paul,
You actually referred these to me some time back. I have a thread detailing the entire process and part numbers.
MSD Wire Install
I actually saw this same set for sale in a "Checkers" (automotive store) for $ 79.00the other day.
The plug ends are very hard to line up, but I have acquired the finesse needed, sometimes if I am really bored I go out and pull the plug wires off just to see how long it takes to get them back on, it gives me a good reason to drink a few bears and cuss in private.
Aloha, Shane
Old 10-23-2008, 09:55 PM
I thought of doing this, but once I had it as a perfect fit I did not want to flatten it again to trace a template. This weekend I can trace the old one and post it as a photo with a grid for printing reference, it will be PDC (Pretty Damn Close) but not perfect.
Old 10-23-2008, 10:03 PM
Arrow Template
I would recommend you use an editing program to get this to scale and then turn the brightness up on your computer monitor and trace it onto paper.
It wouldn't hurt to add 1/4" to the edges just to be safe, you could trim it after final fit.
Use the gray arrows for scale.
The bottom tab is about 1 and 1/2 " its not really needed.
The bend at line A should be angled slightly it is not straight up and down.
Aloha to all.
Old 10-24-2008, 12:36 AM
Whow.
Great idea. I will try doing the same...
Thank you!
Old 10-24-2008, 03:49 AM
Czar of C.R.A.P.
dfink's Avatar
Thanks for the template it looks great. However I just dove in last night and made one myself. Kind of the same process made one then traced and made another. It didn't come out too bad. One thing I did do was roll all the edges to prevent cuts. Also instead of makeing the bolt hole bracket at the bottom I simply extended the bottom it now sits between the cam chain housing and the cylinder. No need for the bottom bolt. I had some trouble with the top getting to curve. It eventually split forming one of your red lines. I cut a piece of 3/4" X 1/16" aluminum strap to follow the top curve and reinforce it. I will try a picture later my picture taking abilities are sub standard to say the least. For reference mine in for a 1984 3.2
66 912 Coupe
Old 10-24-2008, 06:03 AM
safe's Avatar
Super!
Magnus
Old 10-24-2008, 06:15 AM
